SOURCE: Grinder setting for the Rocky SD
Your assumption is correct.
But you do not have to (and you can not) see the grinder wheels to adjust the grinder. The numbers on the bean container indicate the level. All you have to do is to push down the release lever (on the right side) and then turn the container -- towards right for finer grindings (lower number) or to left for coarser coffee. Around 12 is usually suitable for espresso machines.
Willy
SOURCE: rancilio rocky grinder setting
to get starting point you adjust burrs to touch each other. when they touch each other you have finest grinding, after you hear metal voice you turn back 3 dots and grind only for 1 dose. you check it, if it goes to slow, you go one more back and clean gruinder, THAN you grind 1 dose more. 2 or 3 times and you will get perfect grinding.
SOURCE: not fine enough for espresso
solved please donate on my paypal account [email protected] to get the answer
SOURCE: I have a Rocky Grinder. The spring that pulls the
no, dont worry. Just return the lever by hand. Replace the spring and it will break again. It is a hassle to replace and not having it will not affect the function
Grinding setting is one
simple operation but requires bit patience:
PS: the pump pressure of
coffee machine should be from 8 to 10 bar and steam pressure should be from 1.1
to 1.5 bar> depends on type of coffees you use.
