If properly charged your unit should perform fine, having a dirty condensor at that temperature can cause problems not easily recognized.
A well insulated house should be able to maintain a 20 degree temperature difference whether its summer
or winter. No Mechanical cooling or heating involved
for at least 6-8hrs if not more.
If it never cools when it is 95 degrees outside the ambient outside temperature is not the problem.
At 95 degree out side air you should be seeing inside discharge air temperatures betwenn 48-55 degrees.
It is the load in the house that determines how long the unit will run at 95 degress.
