SOURCE: lowrance depth finder missing adapter cable
I own a 1995 Four Winns and what you need is a Lowrance LSM-1 depth
finder unit. It accepts the two pin lead from the transducer and send
the depth reading to the dashboard display via the 6-pin connector.
There is also a three wire harness (red/blk/wht) that connects to a
power supply.
The reason I know all this is my depth finder
fried a couple years ago so I removed the Lowrance LSM-1 from the boat
in order to find a replacement. Unfortunately, this was an OEM part
that is not available from Four Winns or any aftermarket source.
Probably your best bet is to look in a boat salvage yard or purchase an
aftermarket depth finder.
SOURCE: My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
