Televison & Video Logo
Posted on Jun 21, 2010
I need a code and instructions on how to reset, and re programme a total control remote of this model to a pacific televisionnumber ptv 5103 http://www.argos.co.uk/static/Product/partNumber/5341513/c_1/1|category_root|Home+entertainment+and+sat+nav|14419512/c_2/3|cat_15701169|Television+and+audio+accessories|14419521.htm?_$ja=tsid:11527|cc:|prd:5341513|cat:home+entertainment+%3E+television+and+audio+accessories+%3E+television+and+audio+remote+controls#tabrev thanks
5 Related Answers
Anonymous
  • Posted on Feb 18, 2007
SOURCE: Need programing guide and codes for a Jensen 6-device Universal Remote (Jer622)
I have this remote...only Pioneer listings are as follows: TV: 1004,1006,1089 VCR/DVR: 2010,2055,2071 DVD: 3312,3311,3287,3286 To program (for example TV setting): Press and hold down TV while entering code i.e. 1-0-0-4 To manually cycle through all codes (example for TV): Press and hold TV while pressing and holding ON/OFF, after 3 seconds the on/off button light should come on and stay on - release all buttons. Turn your TV on and press ON/OFF once each 5 seconds until your TV turns off. When it turns off, you have the correct code - press the stop button. Good luck.
Anonymous
  • Posted on Jan 03, 2008
SOURCE: Programming a Jensen JER 422 universal remote to a Sanyo Television
To Sarah,
In order to program your TV:
1. Manually turn on your component.
2. Press and hold the component key you wish to program, in your case the TV key.
3. While holding down the component key press the four-digit code using the number keys (0-9) to enter it.
4. After the fourth number is entered, the illuminated ON-OFF key turns on. At this time, release the comonent key. If the illuminated ON-OFF key turns off, you have entered a valid code.
NOTE: For Sanyo TV it could be any of the 8 next codes:
1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180
Good Luck !
Carlos Vallejo
Anonymous
SOURCE: ETEC REMOTE CONTROL MODEL RC5
I LOST MY INSTRUCTION MANUAL AND I NEED TO GET THE TV1.gif CODE TO A sony "tv"
I have an sony T.V. and polaroid. My problem is that I have no code no. for the T.V. and no instroction for the remote. Please help
Anonymous
  • 105 Answers
  • Posted on Jan 30, 2008
SOURCE: programming code for remote control jensen jr321
I am not 100% positive that the JR-321 is supported in the 300 series but.
Jensen JR300 manual - If you cant get it to work using one of these codes it does not support your unit.
http://157.254.235.130/public/IBJ34500SE.pdf
or
http://157.254.235.130/public/J3_4_500_MANUAL_S_E.pdf
Hope that helps!
shirtytrish
  • Posted on Jun 17, 2008
SOURCE: Need remote Control Code for Pacific PTV 7017 TV Model
Hi! I've just bought a cheap universal (NOT 3 in 1/4 in 1) from Asda for £4.50,(model number TVRC1N by Masterplug) and I used the 'search' function as follows;
Power up tv
Press and hold 'tv' button (on bottom right on this control) until led blinks repeatedly
press 0000 ( a black button below the 8)
It should pick up the correct code almost immediately, and then you can test it by turning the tv on and off
Can now get AV1 and AV2
BINGO!
:~D
I need a code for a Live Wire Total TV controller to operate a Pacific TV/DVD combo?(Portable)
0317,0297,0271,0330. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
5103 Not working after dead battery
Your vehicle requires a data/immobilizer interface that controls the door tirggers, brake shutdown, remote starter sequence, etc. When you lost power, the interface lost programming. it need to be reset.
1helpful
I need a code and instruction to program my remote control with a magnavox tv
  • The Magnavox codes are 32114 and 11434. Should those codes not work then follow these steps to do a code search that will find the code inside the remote.
  1. Turn on your TV.
  2. Press and hold down the SET UP key until the red light blinks twice.
  3. Press Programme - three times. The red light will blink twice.
  4. Alternate between Programme- and Power until your TV turns off.
  5. You may have to press these keys many times, so please be patient.
  6. When your TV turns off, press the SET UP key to store the code. The red light will blink twice. Your TOTAL CONTROL is ready to run your TV.
Regards, Tony
14helpful
4answers
Programme a livewire total tv remote
yes go into kitchen open bin drop in these remotes are not meant for our tv/dvd/sat etc they are for a chinese system save your hair chuck it away sorry to say I got one of these oh dear !!!!!!!!
Need code for pacific tele for total control remote
hi i have a universal total remote control for a tv nned a code for a goodmans tv
5helpful
6answers
dude i got the same tv and this is the best answer : D
i have a navy blue sky remote controlling my tv and the code is 0584
Remote control code for tv - Pacific make - model PTV 700S
Do you know the make & model of your tv? We need that info to continue.
1helpful
3answers
Don't have the code for Universal Remote
A great sight with many available manuals.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=totalcontrol
I could look it up too if I had the model # of the remote.
4answers
Do you know the code for pacific tv model ptv 7004
If its not listed in the manual then it doesnt exist
Top Jensen Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
