When mopping my floors with my Shark Steam mop I get streaks of a cloudy film. I tried washing my pad again. I tried with the grain, against the grain. Short passes, long passes. I thought this was going to be the answer and that it would work as well as it does on TV! NOT! Help please
SOURCE: shark steam mop model 3101
Here is the webite to purchase the carpet attachment for your steam mop.
http://www.fixya.com/support/t704954-shark_steam_mop_model_3101
Before you buy the carpet attachment, you might want to read this review. I found it very helpful because I couldn't find much on how it works on your carpet or any reviews on the attachment. Her comments were all positive.
here is the link:
http://www.epinions.com/content_425654455940
Well got one brought it home worked for five minutes. Went back to walmart exchanged my Shark.Only one box left,looked opened but nothing seemed out of place till I got it home.Must have beeen a previous return somebody was short a funnel for their meth.lab(lol).Now warranty or not have tod to take it apart and see.There is a line that looks like it has a tendency to come off it has a spring inside it.Looks like it just blew apart because of pressure (poor design) Going to reattach it see what happens.
SOURCE: My Europro shark steam mop won't steam, light on but no steam.
I just had the same problem and I went ahead and opened the steam mop up with a screw driver and there was the grey pump that pumps steam to the mop pads was clogged with hard water build up and unclogged the pump and it worked right away...
SOURCE: streaking
you maust have some type of wax build up on ur porceline tiles that has not been removed, and should never been used to begin with as poceline is its own finished luster...or you may have used a strong concentration of cleaner that has left behind residue and needs more water clean up.....try looking to see what type of lines,and size the streaks are and decide if they are created by the cleaning pocess or are left behind by the cleaning solution.....good luck...hope this helps..
This type of problem usually
is not he fault of the Shark Steam Mop.
The problem is the old
residue left on the floors by other cleaners.
Here is a tip
that I wrote that will help you out with that problem...
Shark
Steam Pocket Mop Cleaning Problems
heatman101
This type of problem usually is not he fault of the Shark Steam Mop.
The problem is the old residue left on the floors by other cleaners.
Here is a tip that I wrote that will help you out with that problem...
Shark Steam Pocket Mop Cleaning Problems
heatman101
heatman101
