Kirby G6 Bagged Upright Vacuum Logo
Posted on Jun 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The kirby wont start no power
My kirby vacuum wont start no power, couple weeks ago it would start and go with a little jerking around now it just wont start seem electrical but i cant tell. [lease help
Thatvacguy.com
Level 3:
  • Kirby Master 1,619 Answers
  • Posted on Mar 03, 2017
Thatvacguy.com
Kirby Master
Level 3:
Answers
1619
Questions
0
Helped
604889
Points
3345
Start by checking to insure you're getting proper voltage through the cord. Make sure the bag emptor and front brush roll nozzle are installed properly as each must activate the switch for it to run. It could have a defective switch.
5 Related Answers
b0sslady2001
Marci Marple
  • 357 Answers
  • Posted on Oct 25, 2007
SOURCE: kirby G5 vacuum
Here is a link to the help you need,,,
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
The G5 manual is out of print, but the G6 and Ultimate G models are exactly the same and wil work perfectly for your questions.
Marci
Anonymous
  • 1673 Answers
  • Posted on Feb 12, 2008
SOURCE: kirby vacuum
There are 2 safety switchs, one on the front that the nozzle activates, and one on the side that the bag asembly activates. The motor brushes and/or armature maybe bad.
A
Anonymous
  • Posted on Jun 27, 2008
SOURCE: Kirby Sentra vacuum burning belts
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=565459
Generic problem for all Vacuums
posted by campoclan on May 02, 2008
Have had Kirby vacuum for a couple of years since I've had it I burn at least two belts in two months. I keep roller clean, what is the problem?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Some of the problems that people have is that they feel they have to have the vacuum head all the way to the floor and that makes the belt work that much harder. The key to the best cleaning is to raise the height adjustment all the way to the top and once it’s there then drop it down one notch or setting @ a time until you here the tone change. Then try it to see if the vacuum if picking up well if not drop it down one more notch and that should be the setting it is supposed to be for your type of carpet. And remember to use the genuine Kirby belts instead of the Kirby replacements, they will work better. And your suggestion that to keep the brushroll clean and free spinning on each end and also keep the bottom plate clean of dirt and grease because if there is a build up it will move slower and leave black marks on the carpet. I hope this will help and if not contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Anonymous
  • 10319 Answers
  • Posted on Jun 19, 2010
SOURCE: i have a kirby G4 hoover which set on fire
Call or go to him explaining this matter. They should inspect this again since they had done service work t your expense
mc1bean
Mike Cairns
  • 3054 Answers
  • Posted on Oct 29, 2011
SOURCE: How do I change the electric cord on my Kirby vacuum?
Hello, youngh
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about vacuumcleaners and possibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/vacuum-cleaner.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Kirby G4 was surging, then a flash of light and a pop from outlet!
the surge is caused by a faultering armture, might be caused by low carbons or sticking carbons, strip the motor down for inspection. Or take it to your local kirby service centre shop for clean and service and polish. price range from 39 to 59
2answers
I have Kirby sentria that shuts off while using the rug attachment and won't start until I change to the hose attachment. I have had it in Kirby repair store 5 times, cord replaced. Took it back t
power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
Kirby G10D wont power on
head or bag system not fitted correctly refit both
3answers
Kirby G3A Attempts to start but wont run
I would take it in to a vacuum service center. I had a similar issue and they restored the Kirby back to new for $100, it's been running fine now for 2 years!
My kirby generation 3 wont come on
Make sure cord is not damaged. Check to see nothing is blocking hose or carpet nozzle(where beater brush is or brush roll). Plug unit in to a receptacle that you know has power going to it. (Lamp you know works when plugged into same. Using hose on front, make sure bag bottom completely attached to exhaust, the hose has a little arm like thing that will depress the safety switch on the front of the unit, and turn on using foot switch at the back of the unit. If these do not work, it could be one of two safety switches, dirt may have fouled or switch may need to be replaced. Authorized Kirby Dealer in your area: Replacement parts, Kirby Distributor, call: 1-800-437-7170 United States and Canada
3answers
No power
There should be an onboard fuse for the Kirby vacuums. Look on the bottom of the motor. Hope this helps.
3helpful
Kirby 5 Model G5D
is there a re set button on a Kirby. Used the vacuum 2 weeks ago, worked just fine. Went to use it today and it won't start. Any ideas?
Jul 31, 2008 • Vacuums
110-220V
You may have burnt up the motor field when it was plugged into a 220V power source. But there are drop down transformers you can get to reduce the voltage form 210 to 110. AS Radio Shack or similar store would have them.
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
