Question about Olympus Stylus 760 Digital Camera
Olympus 760 error d;8234
Lens does not retract error code 8234
  • 10 more comments
  • Anonymous Apr 19, 2008
    I took the battery out and reintalled it but the lens still won't retract. Made a weird noise a few times..now it won;t do anything.
  • Anonymous May 13, 2008
    Hey!!! i also hav the same problem wid my tiny olympus stylus 760 camera please do help to recover this error D : 8233
    8234
    even i format my memory card also but its not done.actually i wnt to format and reinstall the main OS of the camera but i can't.
    please get me solution as soon as possible.
  • qianzhf Jun 21, 2008
    olympus 760 error d;8234 problem
  • osujipn Jul 26, 2008
    I also have the same problem
  • feilenp Jul 28, 2008
    I agree with the fact it made a weird noise and won't retract. i hope this is a warrantied repair. I have only had the camera for 7 months and charged the battery a max of 3 times only. I really like this camera, but, the lense definitely went out and won't retract. Olympus suggested I send it in as the self help is fairly complicated.
  • Anonymous Aug 03, 2008
    Me too. Lens won't go in, camera won't work, blue screen of death showing D: 5f08 8283 8234
  • lipatov Aug 17, 2008
    yesterday i turned off my camera, everything went on normally/ today i turned it on, objective moved forward, then I heard a scratching noise, and saw a blue screen with this letter D and numbers 8234. Nothing helped.
  • JLB31965 Aug 25, 2008
    I HAVE D8235 AND D8234 ERROR CODES
  • ashley1cat Feb 19, 2009
    lens won't retract and a blue screen in camera says 8233 and 8244
  • rilaguilar Apr 13, 2009
    same problem as every owner of 760 d; 8234 8233
  • Anonymous May 11, 2010
    from what daddygmac9 suggested that should fix the problem. I'm trying to do it now and it's a bit complicated for me unless daddygmac9 will walk me through it ^^;
  • NeonFrog May 11, 2010
    So I took the camera about as I have the same problem with the lense fully extended and jammed.
    The part circled in the pic by linhaserotic, what exactly am I gluing? My part isn't loose. It seems quite solid. I was expecting it to be loose and then I would glue it into position. Can anyone help on the subject please?
It's a little tricky but with a small eyeglass screwdriver and some super glue you can do it. I had the problem, here is what you do. 1 romove the five screws two on bottom NOTE one of the bottom screws is longer than the rest. two on side one on other side. 2 gently remove housing, 3 then remove chrome ring that surrounds three sides of camera. 4 inside there are four screws remove them and separate camera. there is a small metal clip that came unglued you can see where it belongs you must gently turn the wheel till the retainer is all the way to the left away from wheel.the clip goes under the shaft use a little super glue to glue it back. the hardest part is the screen plug lift up black piece line it up and then lock the black piece down it took me about an hour and a half.even with my fat sausage fingers. if you shoot me an e-mail with your phone number i can walk you through it. daddygmac9@yahoo.com good luck
Posted on Apr 12, 2009
  • 7 more comments
  • marcomontesi Aug 26, 2010
    So nice! I've just repaired my mother's camera. Your fix worked for me too.
    Thanks, Marco
  • alex93101 Sep 01, 2010
    daddygmac9, THANK YOU! I couldn't have fixed my Stylus 760 without your directions. To those whom come across these very effective directions, please pay extra attention to the capitalized portion of the following part of daddygmac9's directions: "turn the wheel till the retainer is all the way to the left AWAY FROM WHEEL." As it may vary, either left or right, depending on how you're holding the camera you are repairing. Thanks again, daddygmac9. You saved me having to buy a new camera. P.S. Of the people who thought this was helpful, I was #30.
  • DewChugr Nov 27, 2010
    Thanks so much man, that just saved me buying a new camera, One thing, you said turn the wheel until the retainer is all the way to the left away from the wheel. When I am looking at the back of the camera, top up, it is moving to the right, not left, but yes, away from the gear.
    SUPER tip!!!!
  • red_Rox Jan 22, 2011
    Hi. I don't understand well where I must put the glue from the photo posted by linhaserotic.
    I have put some bottom of it the number 2, as in photo http://img28.imageshack.us/img28/8025/ol... . The clip in metal (number 1, in photo) in which position must be? is it this that must be glued to the number 2? Someone can post a photo of as it must be?... thanks. To push to the left (or right) as this photo http://img193.imageshack.us/img193/927/o... ?
  • DID105 Jul 01, 2011
    wow! i can't believe it but this worked straight away!! thank you so much daddygmac9 and everyone else for the extremely helpful comments! :-)
    WOW this worked right away! THANK YOU!!!!!!!!!!
  • Taylor Risner Feb 19, 2012
    wait can someone explain how do i put the camera back together after I've glued the part. i'm a little confused on it
  • Taylor Risner Feb 21, 2012
    how do i put it back together ? i dont see a screen plug? or i cant find it
  • Skualos Sep 26, 2013
    Nice. Your solution works. Be careful with the amount of glue, and the correct position. You can spin the wheel by hand, to put the "stage" is easier. Thank you. (translated with google ... sorry if there are errors in translation)
This is your problem: http://img169.imageshack.us/img169/9559/12092008108ps6.jpg
That part has got loosen.. probably with super glue you'll fix that..
Btw, warranty wont cover that, it's caused by a fall..
Posted on Sep 12, 2008
    what do i super glue? and daddygmac says to turn some wheel but when i turn it nothing happens ..
The photo and solution does work, but a clarification. The metal clip in the photo has to be BETWEEN the opaque plastic wheel/gear and the rectangular metal piece. The gear turns on threads inside the metal retangular piece, causing the metal piece to move back and forth along the threaded rod. The metal clip that becomes dislodged fits between the gear and the metal rectangle. when the motor moves, it pulls the clip (and objective) to the left. Simply turn the gear until the metal rectangle is to the RIGHT, then insert the clip behind the threaded rod and superglue back in place.
One other thing....if the ribbon connector from the back of the camera comes loose....it slides back into place pretty easy BUT there is a very thin dark locking bar that pushes down on top of the ribbon to hold it in place....make sure that is ok before closing it up.
Posted on Sep 23, 2009
I also glued the part that linhaserotic suggested and photographed, and it worked also for me!!!
I fixed also my camera!!!
I was confused by the phrase "turn the wheel till the retainer is all the way to the left away from wheel" from daddygmac9 . I think it is "to the right". But is is indeed all away from the wheel until the metal strip can be positoned without stress.
Again, many thanks.
Posted on Apr 14, 2009
  • 3 Answers
Take my hat off to you daddygmac9. Just fixed a friends camera, followed your instructions, glued the said part and it works a treat, She will think I'm great...Thank you for posting this solution.
art2105
Solution is a simple fix if you take your time and be careful.
Posted on Jun 19, 2009
I glued the part that linhaserotic suggested and photographed, and it worked!!!
Fixed my camera!!!
Be careful though, there are very tiny and fragile parts inside the camera.
Posted on Jan 21, 2009
    New Friend:
First, THANKS linhaserotic !!
Next, i'm using picture that red_Rox has posted ( http://img28.imageshack.us/img28/8025/olympusu710how1.jpg )
1. Remove part no. 2
2. Turn part no. 3 (weel) right (clockwise) until part no. 1 goes all the way down
3. Drop a little superglue in place where part no.2 was
4. Put back part no. 2 in his place, it goes under the shaft and over part no. 1
Posted on Sep 20, 2011
Could some 1 please help me i really stuck ..which part are ye talking about ??????........i see the picture but i still dont no what part im gluing ????? im getting really frustrated now its been 3 months and stil no joy ...plz plz some 1 help to explain which part im gluing in detail !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Sep 18, 2009
Looks like you should check back with the entry "the lense wont go back into the camera" ... it's the same problem.
The solution posted there explains what probably went wrong, but was complicated enough that you might want to bring the camera by a repair place anyway... I have the same problem with my camera too, and I'm printing out that error message and solution to take with me...
Posted on May 03, 2008
SOURCE:
Olympus all weather 760 errors 5f08 5f0a 5e02 Blue error message lens will not retract makes burring sound help please
The sound your camera is making, is probably the slipping from the gears, grinding them down, because something is blocked. Even when you can't see any blockage. Please don't leave the battery in, to avoid more damage. Contact a certified Olympus repair centre, or visit your dealer with the camera.
Sep 17, 2014 | Olympus Stylus Stylus 760 µ Digital 760...
Stylus760/u760 OLYMPUS
Wonderful.
Share a website with you ,
( http://top4biz.com )
Believe you will love it.
credit card and f ree s hipping.
I bought two pairs. Cheap, good quality, you can go and ship with there
Nov 29, 2011 | Olympus Stylus Stylus 760 µ Digital 760...
Lens will not retract - error codes 5f08 3406 8234
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Aug 16, 2009 | Olympus Stylus 760 Digital Camera
Lens not setting back
The problem you are describing is a problem with a sensor that has failed in the lens assembly of the camera. It needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 18, 2009 | Olympus Camedia Stylus 300 Digital Camera
Error code D: 5f08 8234
Check the power source, make sure the battery is fully charged.
If you have another battery you can try that other battery and see if the lens is able to extend and retract properly.
Try to reset the camera through the menu. If that does not solve the issue then the camera would need to be sent into Olympus for repair service.
Mar 28, 2009 | Olympus Stylus 760 Digital Camera
http://www.fixya.com/support/t513228-olympus_760_error_d_8234
Jul 19, 2008 | Olympus Stylus 760 Digital Camera
OLYMPUS DIGITAL CAMERA 760 ERROR CODE 8234--5E02
I am like you with the same problem, Olympus should be able to answer in how to repair the rubish they built
Jul 17, 2008 | Cameras
Olympus Stylus 760 problem
I just called technical support and they told me the camera has an internal problem. You have to call them if your camera is still under warranty and send it to a repair center.
Apr 29, 2008 | Olympus FE-170 Digital Camera
I just posted this answer on an old Dec. 07 posting.
In case you can't find it, try opening the DC IN / USB port cover just to the right of the dial. This breaks the waterproof seal and allows the camera to open. I think the design flaw is an inadequate volume differential in the water sealed cavity to properly account for the change in volume caused by the lens opening / retracting. The USB cover can be closed once the lens is open to restore the waterproof characteristics.
Mar 24, 2008 | Olympus Stylus 710 Digital Camera
Olympus Stylus 760 Digital Camera Logo
6,355 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
