Have the bulbs been tested and they are good? Do you have power to the lights? if not check the relay and its fuse. If the fuse is popped you have a shorted component, repair that and replace the fuse and or relay.
Someone may have ran the wiring from the fog lights on the same circuit that the headlights are on and therefore it is taking some voltage away from the headlights, might need to run the fog lights on a different circuit with a fusable link in it for safety.
Or you could just pull out the relay under the hood, it's marked fog lights, pull the relay out. If your hi beam indicator is flashing with your fog lights on them selves. Could be the multi function switch. That controls turn signals, headlights, fog, I have seen many of those go bad.
seems your battery has already been discharged by the fog lamp! recharge or buy a new one, but you should fix first the fog lamp before hooking your battery! check for stuck -up relay!
Fog lights are connected to pin 13,14.
Fog light switch is "B". Because the current is many Amps, contact surfaces are heating up.
After that the contact opening "C" is melting (made of plastic) so the fog light stays "ON".
