How to set up GPS and map and wifi in corby pro
I will tell you how to set up wifi in corby 1st because it will come in handy in the second part.
1) 1 st go to menu and scroll to the right screen where the wifi shortcut is detected.r phon
2)Click on wifi and it will open and then click on the grey bubble which says wifi, this will activate your wifi.
3)Now click on search, and now your phone will search for available wifi signals.
4) If a wifi signal is available click on it and click connect. If you are accessing wifi from this source for the first time a window will pop up describing the wifi settings, now click on save and it will be saved.If the connection is a secured connection you will have to insert the password in the details
5) After saving the settings your phone will be connected to the network.
6) Once it is connected click on the wifi provider link and click start internet, now you can browse internet using wifi
To set up your gps
1) Go to menu click on settings
2) In settings go to phone settings
3)Select GPS settings
4)click on GPS + settingsr
5)Click on download data and then the phone will download data for your gps, you have to choose a profile for downloading the gps data that is whether if you are using gprs or wifi. Click the profile and you are done .
6)You will download data and to check position click on gps position in gps settings menu
