Kenmore 24 in. 15079 Built-in Dishwasher Logo
Posted on Jun 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a white powder residue on my dishes after a cycle. I do not have hard water and am not using too much detergent. I am doing the same thing I've always done, only now all of a sudden I'm getting white powdery residue.
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on Mar 03, 2011
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10838318
Points
101584
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Why is there residue on my dishes when the dishwasher is done cleaning
All the reasons
The cause of this problem could be limescale or salt residues. If the residue can easily be wiped off with a finger, it is likely too much salt. If the residue is difficult to remove and comes off with vinegar, it is likely limescale (hard water build-up).May 29, 2023
Dishwasher leaves white residue on dishes and cutlery
Electrolux https://www.electrolux.co.uk > dishwashing > dishwashers
Why Does My Dishwasher Leave Residue on Dishes?
C&W Appliance https://cwservicesinc.com > Blog
Soap is one of the substances that can cause your dishwasher to leave a residue on your dishes. You can prevent it by doing the following: ·
How to Get Rid of White Residue in Dishwasher
Paradise Appliance Service https://paradiseapplianceservice.com > dishwasher-repair
Jul 7, 2021 - If you notice a white residue on the outside of the dishwasher door, it is likely caused by either using a subpar detergent or too much of it.
How to Stop White Residue on Dishes From a Dishwasher
Hunker https://www.hunker.com > ... > House Cleaning
If the water is too cold, the dishwasher leaves white residue behind in the form of undissolved soap. Check your hot water heater and make sure it's heating ...
Dishwasher Leaving Soap Residue (Causes & Troubleshooting)
howdykitchen.com https://howdykitchen.com > ... > Dishwashers
Jul 17, 2022 - The most common causes of your dishwasher leaving soap residue on your dishes are you're using too much detergent, you're using an incorrect ...
Luce Home https://www.lucehome.sg > blog-article > how-to-get-r...
Sep 2, 2022 - Hard water isn't the only culprit. Your dishwasher detergent may be to blame for the white residue on your dishes. Low quality liquid detergent, ...
How to keep white residue off your dishes
Homestructions https://www.homestructions.com > appliances > keep-...
Open the door and add two cups of vinegar. Turn the dishwasher back on, and let it complete the cycle. The acid in the vinegar will break down and remove the ...
What Dishwasher Residue Means And How To Get Rid Of It
Repair Aid London Ltd https://www.repairaid.co.uk > help > residue-issues
Detergent. Another common dishwasher residue problem can be caused by detergent. This is often caused by the usage of more modern, phosphate-free detergents.
Aug 27, 2023 • Dishwashers
2answers
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
White powder in washer after clean cycle
If you live in an area with hard water, the white powder is probably hard water residue / deposits. Most detergent does not clean hard water deposits anymore because there are new laws that required a change in the ingredients of dishwasher detergent. Here's a product that was created to solve this exact problem. Add about 2 tablespoons to your normal detergent. It's all-natural & made from dehydrated orange peels! They will send a free sample if you ask for one. www.CloudyDishes.com
Hard Water Stains Cloudy Dishes Dishwasher Detergent
1helpful
White powder residue left on dishes after washing. I run hot water before running dishwasher, use Cascade powder (fill dispenser less than 1/2 full per installer and do not use prewash detergent...
heatman101
2answers
White residue left on dishes; Plastic ware being oxidized
heatman101
It is leaving an enormous amount of white residue on our dishes and is causing all of our metal dishes to come out dark.
The white residue could be from one of two sources.
Detergent Residue:
Using too much detergent or poor circulation of water can leave a white residue on the dishes. If the residue is easily rinsed off with warm water then it is detergent. Use less soap, especially if you pre-rinse the dishes or have soft water. Use a hi temperature wash to help dissolve the soap better.
Hard water deposits:
See this link where I put together some information on this.
http://www.fixya.com/support/r4666624-hard_water_calcium_white_powder_build_up
2helpful
2answers
Dishes not completely drying and white powder residue left.
Do you have a water softner? If so you are using to much soap in your machine. Go to wal-mart and buy a container of dishwasher clean ( it is by the rinse aids) run that through to remove any excess soap and then cut down on the amount of detergent that you are using. 1-2 tablespoons only.
16helpful
6answers
New dishwasher leaving powder residue on dishes.
Quit using the new Cascade. The formula change is what is causing the problem. No research from Cascade before releasing the product
Nov 18, 2008 • Dishwashers
8helpful
2answers
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
