Question about Kenneth Cole Black Face with Stainless Steel Bracelet KC3393 Watch for Men
What battery is needed for this watch wen it goes out
    Genius:
  • 1,970 Answers
Mcdevito75 here, Possibly a 377 or 364, look for a small watch repair shop, they can tell for sure as I would need the watch here with me in Florida to tell for sure.
Posted on Jun 20, 2010
SOURCE:
Wen i press the light button the watch screen dissapears
I'm sure it is low batt.. replace a new battery and it works properly again.. i'm happy that i have been help you..
Jan 05, 2013 | Timex 27191 Wristwatch
My Abacus Fossil AU4005 110504 wont charge any more,wen i put it on the charger nothing happen,it does not light up any more,do i need a new battery and where do i get it?
I had the same problem but easy fix.
first make sure you put the watch on charger for a few hours first-- the problem is not the battery not taking charge it is the watch that is not turning on probably.
After a few hours on the charger, remove the four screws on the back cover-- WARNING- remove cover carefully. there are two thin copper wires attached to the cover to the charing coil. set the cover aside. remove battery back (unplug tiny connector). WAIT a10 minutes-- this is to discharge any remaining charge that may be held by capacitor in the watch. plug the battery back in. Voila! working now. This is my way of resetting the watch to factory setting. Isn't it almost always work when you remove power to electronic device to reset it?
Nov 09, 2012 | Fossil Abacus AU4002 wristwatch
My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
Jan 11, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
Digital watch goes too fast
maybe replace it with same orignal battery and if battery it rite the crystall oscilltor ia damaged
Jul 29, 2010 | Casio AW80-1AV Wrist Watch
Had new battery installed in Howard wrist watch, cannot get the correct time. The date is correct.
You don't say which model you have but if it is a radio controlled watch, then try re-setting the location, it frobably "forgot" where it is and wen back to the original factory setting.
Jul 17, 2010 | Watches
Need battery model number
the size cell that goes in this watch is a 395...good luck :)
May 17, 2009 | Luminox 3102 (Size: ) Watch for Men
Second hand on my watch now goes in 5 second intervals
Check the instruction manual if you have one. Tag-Heuer watches move in 5 second intervals to let you know the battery needs replacing. A neat feature. Now you know that you have a real Tag!
Dec 30, 2008 | Tag Heuer Link Automatic Chronometer...
When I press light buttopn in the middle the display goes blank
This sounds like a simple battery replacement. Depending on how low the battery is usually pressing the light button and the display goes dim or blank is a good indicator of this. Takes a CR1616 battery and be careful of the spring inside and make sure the seal is in the correct position. You will need to touch the AC button and the back of the battery with a pair tweezers for a couple of seconds to reset the watch. Put the case back on and set the watch thru the functions.
Dec 06, 2008 | Casio Baby-G BG169-2V Wrist Watch
Kenneth Cole Black Face with Stainless Steel Bracelet KC3393 Watch for Men Logo
59 people viewed this question
Top Kenneth Cole Watches Experts
Janelle Schoonover
Janelle Schoonover
Gary Nitowski
Norman Worley
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
