SOURCE: LG DISHWASHER LD-1204W1
Try turning your tap off a bit till the noise stops but the dishwasher still fills, it can just be due to a bit too much pressure on your water valve.
hpe this helps
SOURCE: I cant get the filter out of my L G dishwasher
some have little tabs to push to unlock the filter. what is your model number?
SOURCE: ld-1204w1
What did you find the problem to be?
On an LG dishwasher, I am not aware of an E0 error. But there is a "OE" error code (as in output error)
The first thing to check is the lower sump area - remove the filter beneath the spray arm and look everywhere for blockages that have slipped through. If that is not the problem, the drain motor has probably failed.
Good Luck!
SOURCE: dishwasher model LD-1204W1 after 2
Hi.
The problem is likely the hinges.
Unfortunately this is an Australian model, and I cannot show diagrams and pictures or provide service manual for the specific model.
The hinges are located at the sides of the appliance. With LG dishwashers you will have to remove the door liner to access the hinges.
I am not sure if the model in service manual below is the American equivalent, but it is very similar. The door assembly should be more or less the same.
Please click on the link below and see page 14, where explains how to remove the door.
Service manual.
Regards.
Ginko.
SOURCE: E1 error on LG washing machine LD-1204W1
Hi gmann947,
*Nice nickname, reminds me of Jeremy Mansfield, a retired radio presenter on 94.7 fm - Hehe*
To help you with your request, I'd advise you to look at my Tip below, it has the full description on how to fix the E1 error:
L.G DISHWASHER E1 ERROR...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it.
