Would you please provide me with the model number of your unit.
the model number starts CECH__01 i need this number the underlined in the number here is where a letter is put please advise me of this number this number will be located on the back of your unit. next to usb ports
please try these trouble shooting steps.
1. unplug the unit and press and hold the power button for 30 seconds. this should drain the memory and reset the unit. plug the unit back in and hit the eject button. this should turn the unit on and the tray should come out. the reason your screen this has happen is because the region on the dvd may not be for the region of the unit made. if this does not work. they are highly advise you to contact service. you reach them at www.ps3.com and click on service.
I'm not sure what the model number is but I have two numbers.
FCC ID:AK8CBEH1000
IC:409B-CBEH1000
I hope one of those were the right numbers.
It is A
Ok thank you I will try that but my PS3 does not eject a tray, it is an original 60gb PS3 but I will try anyway. Will this procedure wipe my system of everything?
I also have used this dvd many times before.
Sir,
Thank you very much, your assistance was very helpful though I figured out the problem. I jumped to conclusions, a stupid problem though it may seem, my HDMI cable on my TV was a bit loose...I checked it but I suppose I didn't carefully enough. Thank you again for your help, I will recommend your service to friends that have real PS3 problems.
Jesse
