Canon PowerShot SD780 IS / IXUS 100 IS Digital Camera Logo
Posted on Jun 19, 2010
My Canon PowerShot SD780 IS camera has a black screen that's having problems turning on when powered up. Is there a fix for this?
5 Related Answers
t00nz
CameraR
  • 4738 Answers
  • Posted on May 27, 2009
SOURCE: Black screen problem with Canon PowerShot SD 750
Did you accidentally press the DISP button on the back of your camera? This manually turns the screen on and off to save batteries. Try pressing this button one more time to see if it turns the screen back on.
Anonymous
  • Posted on Mar 07, 2010
SOURCE: Canon PowerShot SD780 IS camera lens error. :(...
I did the same thing and it works only be restarting it now but it works lol. I threw it agianst my bed . SO BEAT THE **** OUT OF YOUR CAMERA..then restart and it should work..*** made **** what can you say
Anonymous
  • 11 Answers
  • Posted on Jun 23, 2010
SOURCE: Canon powershot SD780 is camera. Camera shows the
There's really no way to restart it if there's a physical problem with the lens. Try to power it on again but if that doesn't reset it, the camera needs to be serviced. A great site for help with these is: camerasandparts.com They just specialize in service for the Canon Powershots and nothing else, they are fantastic if you need help with one of these problems. Try them, your exact SD780 lens error restart camera problem is right on the site for the SD780. Good luck, that's the place for help with a powershot, it just sucks that it happened while you are on vacation.
t00nz
CameraR
  • 4738 Answers
  • Posted on Jun 26, 2011
SOURCE: canon powershot sd780 is/ixus100 is digital
This seems to be a particular issue with this model camera, noting by the Fixya archived problems for this model. Noting that the slide switch doesn't seem to correct this problem for the majority, the only other possibility is that the corresponding switch internal to the camera might be gummed up. As such, please see the "toothpick fix" (Fix #4) of this link.
t00nz
CameraR
  • 4738 Answers
  • Posted on Nov 10, 2011
SOURCE: Own Canon Powershot S500. Turn camera, on getting
Go to Canon as FIRST resort. They'll fix this problem free and easy with free shipping too (see this). Call 1-800-OK-CANON right now and tell them the problem.
Memory locked is displayed on the screen... I tried the switch on the side and still it wont work. Even tried another memory card still have the same problem. How do we fix this. Cam model is power shot...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". There are also other common causes if moving the slide switch didn't help, with troubleshooting steps for this problem listed here.
9helpful
My cannon power shot sd780 lens cover does not open when turned on. Just a black screen. The barrel does extend. Is there something I can do to fix it?
Its not easy to dismantle this kind of gadget, a broken gear inside or some mechanical parts of the lens assembly caused lens not to open or a motor controller itself, so better to find a cannon service center ear you.
7helpful
2answers
Canon powershot SD780 is camera. Camera shows the canon screen then turns black and beeps three times then says "lens error restart camera". I don't know how to restart...i need to use it I'm on a trip...
37helpful
7answers
3helpful
2answers
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
