The dryer gets too hot and causes the breaker to trip. When I take the lint catcher out and prop open the lint catcher door, it runs longer before causing the breaker to trip. Can I run it without using the lint catcher? Is this problem fixable or is a new dryer in my future? The dryer is only 6 years old...
The vents are most likely stoped up . All the lint & anything around the fan all the way to the outside vent needs cleaned . I have found a lot of things in front of the fan nails coins & whatever that were in clothes pockets sometimes the lint or other things won't let the fan turn & the breaker or thermal fuse to blow. Hope this helps
SOURCE: kenmore dryer
Jeff, almost sounds like a timer issue, but I was fooled on this once. Under the consol is a inline resistor from the main plug. If this resistor is bad, dryer keeps running in timed dry. Part number for the resistor is 3401076. Look it up on the web so you know what it looks like. Just splices in.. Catriver..post back.
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
SOURCE: dryer keeps tripping breaker
THE BREAKER IS GOING BAD REPLASE IT OR THE BREAKER IS TO WEEK FORE IT TRY ANATHER PLUG
SOURCE: Circuit Breaker is tripping when tumble dryer is
Circuit Breaker is tripping when our tumble dryer, creda 522vw, is turned on. Have removed back and top of tumble dryer and cleaner all excess lint, checked connections and exhaust. Any ideas please
SOURCE: Power Button will not turn on.
Verify proper line voltage is present at the outlet. This will require the use of a voltage meter. If not properly trained, I would consult an electrician to verify the voltage.
Part of the troubleshooting proceedure requires the technician to verify that the applience is receiving the required supply power.
This has to be verified at the outlet to eliminate the possibility of a bad breaker or bad connection inside the breaker panel or outlet box.
Hope this helps in finding the solution to your problem..
Thanks and good luck..
