2000 Pontiac Grand Am GT Logo
Posted on Jun 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I reset the "Change Oil" light on a 2000 Pontiac Grand Am?
Roger Foster
Level 3:
President:
  • Master 701 Answers
  • Posted on Jun 18, 2010
Roger Foster
Master
Level 3:
President:
Answers
701
Questions
Helped
437230
Points
3451
Hello tiffinkie: My name is Roger an I will help you. First open the passenger door and locate the fuse panel located in the end of the dash cover. Remove the cover turn the key on. Do not start the motor. Push the reset button located at the top of the instrument fuse panel.The CHANGE OIL light will start to flash.Press and hold the RESET button again. The reset is complete when you hear the chimes sound and the CHANGE OIL light goes out. Should you need further help please just ask. Please rate your answer. This way I know it was helpful. Thank You for using Fix Ya. Roger
1helpful
After oil change how do you shut off the change oil light
Open the fuse panel between door and dash there should be a reset button turn key to run position without starting press button till oil change light flashes and tone sounds then turns off may have to push button several times
Just bought a 2000 pontiac Gt with 110000 miles on it two days ago. Ive driven it 137 miles before the service engine soon light came on. What do you think it is
The service engine light is usually a flag for an oil change or other maintenance item. If it is reset, it will come back on in 5000 miles as a reminder to change the oil. Ask your dealer's service department how to reset the indicator and do it when you change your oil. I know for Saturn, the proceedure is Turn the key to the on position without starting the engine and within 5 seconds press the accelerator pedal all the way to the floor 3 times. Not sure if it will be the same for the Pontiac, but you could give it a try.
2000 pontiac Grand Prix - digital display in dash - oil life % reads LOW. Just came on. What is this telling us? we checked the oil level and that is just fine/
It's the indicator that it's time for an oil/filter change. I am not sure the procedure to "reset" the light, Sorry.
How do you reset the " change oil light" on a 2000
turn key on without starting engine, and press gas pedal to the floor 3 times quickly. start car. done
How to turn change oil light
iI you mean 'how to turn change oil light off" go to fuse panel. Open drivers door there is a panel cover on the side of dash board, remove cover there is a red RESET button that resets oil pressure and tire pressure. Turn the ignition key to the on position but don't start the car. Now press and release the reset button the change oil light should start to flash, now press and hold the reset button until you hear chimming hold until chimming stops then release, the change oil light should go off. If you need to reset tire pressure press reset button twice, the first push will make the change oil light flash the second press will make the tire pressure light flash then hold untill chimming stops, light should go out . Hope this helps.
2helpful
2002 Grand Prix: I just had my oil changed in my Pontiac 2008 Grand...
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds. and wait for the light to flash. Check your manual it maybe slightly different. Real easy fix.
1helpful
How do I reset the change oil light in a 1997 Pontiac Grand Prix 3800
To reset the oil life indicator, press the MODE button until the light next to OIL LIFE is lit. Press and hold RESET for 3 seconds until oil life percentage is 100%.
2helpful
2answers
How do i reset the oil light?
Pontiac Grand Am, 1999-03
To reset the Change Oil light, open the driver’s side instrument fuse panel cover and turn ignition on engine OFF. Press the RESET button and release. The change oil indicator light will flash. Press the button again and the system will be reset.
Good luck and happy new years.
7helpful
2answers
Can't get the Change oil light off
Turn the key to the on position and press the gas peddle down to the floor 3 times within 5 seconds,then wait 10 seconds. Turn the key off then start the car,the light will be off :)
Top Pontiac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
