RIM BlackBerry Pearl 8120 Cellular Phone Logo
Posted on Jun 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I try sending a text message a red x appears and the message does not send
Kerrie Jager
Level 2:
New Friend:
  • Expert 45 Answers
  • Posted on Jun 18, 2010
Kerrie Jager
Expert
Level 2:
New Friend:
Answers
45
Questions
0
Helped
10119
Points
147
First of all, make sure that you have service and that your service includes text messaging. If you have all of the above, without powering off your phone, take the back of your phone off and take the battery out. Leave it out for a minute or so and place it back in. Replace the back of your phone. Power it back on. Retry sending messages. I hope this helps.
4 Related Answers
Anonymous
  • 13 Answers
  • Posted on Feb 23, 2009
SOURCE: unable to send text messages
Generally if the phone is giving a "cannot send" or "message failed" error message then there is something wrong with the "switch" In order to fix this you need to contact your providers tech support and they should be able to fix the issue...
You can also try sending the picture to your own number... sometimes that will help push it through the switch...
Also make sure that you are using the area code of the numbers that you are sending it to...
Alltel for example, will not let the message go through if the area code is not inserted
9ayan
Bong Marley
  • 65 Answers
  • Posted on May 28, 2009
SOURCE: phone not receiving/sending text messages
reset or format the phone..... backup ur data first...
Anonymous
  • 3 Answers
  • Posted on Aug 02, 2010
SOURCE: i am unable to send text messages in nokia 5230 .
simply restore factory setting by "*#7370#" it is hard resetting so will loss all your data. First backup all data
Anonymous
  • 4102 Answers
  • Posted on Oct 09, 2010
SOURCE: I ca'y send a text
Hi the problem you are having is with your message center number this is a common problem and usually happens after you have changed your sim card to another network all you need to do to solve this problem is call your service provider and tell them the make and model of phone you have then ask them for the correct message center number.
they wont charge for this and they will tell you how to set it up, you will also need to ask them to send you the latest wap and mms settings so you can use the net and send and receive picture messages. they wont charge for this either and they will send you these settings via txt message and this will then update your phone to the latest settings.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
`12
Why am i getting a red triangle and it want send a text?
Either your Cellular Data is turned off and you're trying to send an iMessage, or you don't have any service and your trying to sent a text message. If you're trying to send an iMessage, turn your Cellular Data on. If your trying to send a text message wait until you have better service to send the message.
Sms restriction 45
TracFone International Texting Revoked
  • Certain mobileicon1.png phone upgrades affect the ability of TracFone customers to send text messages internationally. Some of the phones identified to have had this SMS issue are the LG290C, LG420G and Samsung T301G. The problem is present when an error message appears on your TracFone device after you send a text message to an international number that says, "Check SMS Restrictions."
Read more : http://www.ehow.com/info_8634048_trac-phone-problems.html Did you upgrade from the 420G to 440G? Certain mobile phone upgrades affect the ability of TracFone customers to send text messages internationally. Some of the phones identified to have had this SMS issue are the LG290C, LG420G and the Samsung T301G. The problem is present when an error message appears on your TracFone device after you send a text message to am international number that says, "Check SMS Restrictions"
Or your phone isn't capable of texting internationally.If it's supposed to then you need to call Tracfone customer service and tell them.
1helpful
My Motorola Photon Q will not receive or send texts or calls, what can I do?
I would check with sprint to see if your account is up to date. Otherwise, I would suggest going to your settings and see if you can update your phones's prl and profile. go to settings, tap "About phone", Tap "System updates", then tap each option. Good Luck!
Flashing red light on my triumph and text messages arent sending
for sending text messages :
1.go to your message settings and check the message center number to see if it is correct
2. call to your network operator customer care
3. request the message center number...
4.note it down
5. go to message settings>message center number
6. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
I can not send any texts. Had no problems before. Keep getting the red exclamation point and say wont send
GO TO TEXT MESSAGE SETTINGS AND SEE WHETHER MESSAGE SEND VIA IS TEXT OR NOT IF NOT MAKE IT TO TEXT AND TRY....
1helpful
When sending sms a red clock appears when i send
This indicates that the phone does not have sufficient coverage to send the text message. Try moving around to an area with better reception. If it's still a problem you may want to reset the phone by taking out the battery for 30 seconds and putting it back in.
Hi ! Every time I try to send a text message, it appears Memory full! Close some applications and try again.I did erase my pics as well as those file saved in my memory card, but it still hopeless. It's 3...
Go your message setting. There is option where you'll save your message and choose save to memory card.
Delete all message in inbox and outbox folder, delete all cache in your browser and close all active applications. Try to send text message.
If the notification "Memory full" still appear you must uninstall a one or more application (not just close it but uninstall it) to make some space in your phone memory. Choose application that you don't use the most.
If the problem persist, format your phone back to factory setting.
Hope this help and if helpful RATE please.
Feb 09, 2011 • Nokia 3230
1helpful
Can recieve text messages but cant send them messages center number appears when i try to send text
hi there,
call the customer service of your service provider ( AT&T,Vodafone,Verizon etc)....they will set up message center number on your phone , the one that you have might be incorrect...your mobile operator will send you sim updates that will refresh the settings ....and then you will get the text message options
cheers
When i text message and send then message sending
checki ur message service centre no. if u dont have it or have it corrupted, contact ur customer care and update ur message service centre no.
2answers
I cant send sms text messages. When I send it
For this please check if for the network issue buy sending a PIN to PIN message if you are able to send a PIN to PIN message then the network is fine if you are still getting red X the contact your service provider so that they raise a service request to the network team.
Hope this helps you
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
