Record LP records to CD, using a 1978 B&O turntable, old Marantz receiver, 500 albums, a Laptop, and a cheap connector?? without buying expensive equipment, while getting great sound. I heard that you can just use an RCA cable with a Y on one end, and plug into the Microphone jack on the Laptop. It's hard to believe that this would provide original sound, and I don't know anything about electronics to know exactly how to do this. I haven't heard my records for about 15 years. Please help. I don't have the "beosound shelf system" listed, but couldn't get this to enter without choosing some kind of category.
All you need to do is connect two RCA plugs into the audio in of your laptop. The two RCA's go into a tape out of the recevier. If your laptop uses 3.5mm plugs for audio conections then get a 3.5mm plug to RCA plugs. See image below.
To record the music and convert it I would get Magix Audio Cleaning Lab, which you can pick up cheap on Amazon.
The sound will then come out of your speakers on your computer and then you can record it with Magix and convert it with the software to any audio format.
Testimonial: "This gives wonderfully detailed info with pictures, which a girl like me needs. Will the sound that comes off my recorded CDs, using this method, sound as perfect as playing the original albums directly on the turntable? Thanks so much!"
The software I told you about will make them sound just like a CD! However you can't do anything about a record that jumps. The declicker will take out about 99% of scratches, (that 1% will be severely bad if it can't remove it) another part of the software will remove hum/rumble and other strange noises. And another part can increase/decrese bass/treble. You can make CD's with it too! You can even put 78 rpm records in without having the 78 speed on your turntable!!
I added a question in my testimonial, but to make sure you get it: Will the sound played back on these CDs I record sound as pristine as the original albums played back on the turntable directly?
Thanks for the extra info! I googled Magix, and found a review on CNet, which offered a free one week download (If only I thought I could record 500 albums in a week, it would be FREE). Somebody on Fox local in Dallas did a report on a unit by Grace, which they tested on cassettes (which I have a lot of that I would also like to record, but mostly the LPs are most important). They said it worked well, and could be found for about $69 online. I have pretty sensitive hearing, and wanted to make sure that what I get is the best I can afford. Magix got a pretty good review, overall, and I'll trust your judgement. After all, you are listed as a Guru.
