Question about Homelite Mighty Lite Lawn Trimmer
Will run but when given gas it chokes down
Homelite weed eater model ut20004a will run with the choke on but when given gas it will cut off but will crank back up but same results?
    Sergeant:
  • 333 Answers
Adjust the choke
Posted on Jun 19, 2010
6ya staff
SOURCE:
My weed eater will only run when choke is set to half
suggest fresh gas and check your fuel filter in tank , then I would probably make sure that none of your fuel lines have cracks, then all else fails you will have to remove your carb and dissasemble it and clean it out ,probably partially plugged from old gas, hope I helped you
May 02, 2011 | Homelite Garden
My weed eater wont turn on it keeps turning off as soon as turned on it is really frusterating sorry if i spelled that wrong
Most two stroke engines in weed eaters require a premixed fuel combination of gasoline and two cycle oil. I am assuming you have a gas model which needs a gas and oil mixture. A possible problem is the choke is turned on, and once it starts you need to move the choke to run. Another possible problem is the gas oil mixture is incorrect, and you may need to remix the fuel to the manufactures recommendation.
Jul 23, 2010 | Garden
Weed eater starts but won't stay running
just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Weed Eater Problems
If it runs with the choke closed then it's not getting enough gas. Check the gas filter on the end of the gas line in the gas tank. Remove the gas cap and using a piece of wire with a hook on the end, reach in the tank and pull the gas line out through the opening. Check the filter on the end of it. You could also have a burst-ed diaphragm in the carburetor. This sucks the gas from the tank to the carb. If that's the case a new weed eater may be in order unless you can find someone with the parts to repair it. Also check the gas lines for leaks or breaks, 2 of them.
May 17, 2010 | Troy Garden
I have a ryobi weed eater clean carb change filter and spark plug wont run off choke
I have the same problem. It will run if I put it halfway between Half Choke and Full Choke. But, just dies if I put it on Run or Half Choke. Don't ever loan your WE to anyone, They might just try to run it on straight gas--That is what happened on another week eater that I had.
Mar 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Ryobi weed eater loses power at working speed after 5 minutes.
you need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
Aug 21, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Homelite Mighty Lite Lawn Trimmer  Logo
748 people viewed this question
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
Joseph Mueller
Joseph Mueller
Are you a Homelite Garden Expert? Answer questions, earn points and help others
