Nokia 5800 XpressMusic Smartphone Logo
Posted on Jun 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
5800 MMC NOT WORKING - Nokia 5800 XpressMusic Smartphone
Anonymous
Level 3:
  • Master 484 Answers
  • Posted on Jun 18, 2010
Anonymous
Master
Level 3:
Answers
484
Questions
0
Helped
163074
Points
1488
If you Nokia 5800's memory card is not working.
It simply means there is a problem or two,
1. the phone might not be reading the memory card,
2, the memory card might be faulty.
test to know if it is the phone,
  1. insert the same memory card into another phone to see if the phone will read it.
  2. insert another tested okay memory card into the phone to see if it will work.
  3. if it does not,then the fault is from the phone,
to fix this,
  1. get the appropriate screwdriver,
  2. open the phone,
  3. carefully open the memory card slot,
  4. clean it properly with naphthalene and dry it under the heat of a bulb,
  5. or you can replace the memory card slot completely,
  6. insert the memory card and turn it on to see if it will read it.
  7. before you couple it back together.
To test if it is the memory card
  1. insert the memory card into another phone to see if it will do the read it, if it does not, then the fault is from the memory card.
to fix this
all you have to do is to change the memory card.
take care
Unoccassional restarts on nokia 5800
Format your mobile code is *#7370#
before performing that please back up and scan your memory card for viruses and try to use once your mobile without your mmc you can come to know chances of virus
I forgot my password of a memory card of nokia 5800 music express?i want to unlock it.
Hi you can't unlock the mmc password by any means.But the only thing you can do is to visit mobile repairing shop.They can generate the password with the help of mobile repairing tools like Advance Turbo Box,Mx box etc.Thanks for visiting fixya
How to unlock memory card 5800
Format the mmc card with the mmc card unlocker and then format the mmc in your pc and enjoy
Unable to send text messages
You have virus in your MMC take your memory card out and then try. still does not work update for new nokia software
1helpful
My phone want pass cod for memory card which i never define it.
download a filemanager to your phone. i recommend best fileman
In the file manager you'll find under- C:\System\mmcstore -the file you're looking for, you have to rename the file- mmcstore.txt -then send it to another mobile or your PC via bluetooth open it on the other phone and your password will be revealed.
Rename the file- mmcstore.txt -to just- mmcstore -there might be another file named- mmcstore.txt -to view your password rename one or the other- mmcstore1.txt -one is for your phone PIN number the other your MMC card.
1helpful
Ok well basically my phone wont let me delete any of my old music so its building up and now i can get any new stuff on im using the nokia 5800 and its driving me a bit mental any advice
hi friend,,,
format ur memory card,,,if its not letting u to do that..ur mmc(memory card) may be corrupt...ok do one thing.if u have card reader ,,then its ok.after inserting mmc reader select FAT 32 format not the NTFS system and fornmat it,...it will work
thank u,,,,,PLEASE RATE IT
HI, I had to format my Nokia 5800. Now it asks me to insert a pin for my memory card. i have tried the usual ones like 00000 / 12345 but nothing works. What can i do?
You can recover the password, the best way is to download a file manager to your phone. I recommend Best Fileman
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
