Just installed a connex cx 3300hp not sure of settings for cb example channel 16 mode switch am fm pa? band selector switch d/a e/r f/c? band hi lo ? thanks bill
the switch with E/A, F/B, G/C, H/D is the band selector. the switch with PA, FM, AM is the mode selector. use this switch if you want to work on FM or AM.
MAKE SURE ALL THE CONTROLES ARE SET CORRECTLY R-R GAIN CLOCKWISE FULLY, SQUALCE COUNTER CLOCKWISE FULLY AND HAS THE RADIO BEEN MODIFIED FOR THE 11 METER BAND BY SOMEONE
FM is just a form of modulation, not an actual frequency. The frequency doesn't change between any of the modes (LSB, USB, AM, FM, CW).
For example, if you are on channel 19 (27.185MHz) on AM (Amplitude Modulation,) switching to FM (Frequency Modulation) mode you would still be at 27.185MHz, but using a different form of modulation.
turn the rf gain all the way uphave your pa fm am knob on am your band knob on your desired band hi rf power band hi or low depending on wich ever u want to uss
