HiI don't think master code can help you to unlock your security.But the best way to solve this problem is to contact mobile repairing shop.But before you visit mobile repairing shop follow this step, first remove battery from your phone and leave it without inserting the battery to your phone for 15 minutes(minimum) and try with the correct code or 12345.Good luck
Firstly never try to use local battery because they are not good enough and damages handset . check your battery in other mobile if its works in other mobile then your handset need to be FLASHING ie. updation is required. Update your handset and never use local battery always use nokia brand. Thanks to help you
the default PUK is 00000000 (eight zeros). How ever PUK is a domain of ur network provider. It may change accordingly with different networks. Call up ur customer care support they would definitely give u the code
did u try the master code ..if no give me your imei no. i will give u ur mastercode if the code is not working then no other option than formattin ur phone...
