If the freezer is freezing everything, check the coils. A refrigerant leak will cause ice to build up on the coils, not extra ice in the fridge. ... A leak in the compressor or coil will chill the air around the leak as long as it is outside, but a leak into the fridge could cause it to get extra cold.31 Aug 2015
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing. Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
IM guessing your icemaker is not working either. these symptoms are caused by your evaporator fan motor not blowing air throughout cabinet. However, your problem could be the motor itself not operating correctly, wr60x10185, or the main control board is not operating correctly, wr55x10942. the problem with the board can and often will be caused due to a faulty motor, so both have to be replaced. It would be much too long for me to explain how to test everything you need to test to see source of problem, but your symptoms are definitely caused by that fan motor not running.
I had a similar problem where my evaporator coil was freezing into a block of ice, which caused my fridge to warm up due to a lack of air flow. I fixed this by doing a few things. I replaced the circuit board ($100) which was easy to do. Unfortunately, this didn't fix my problem so I took the inner fridge cover off to view the evaporator/heater coil assembly. I checked my thermo fuse and found it to be open (failed). I ordered the thermo fuse and the thermistor and replaced them both. I then plugged the fridge back up and put a regular thermometer inside the fridge to get an accurate reading of inside temp. A few days now and everything looks good. The board, fuse, and thermistor were all pretty easy to replace.
Your damper that controls the air to the fridge side is stuck open. It can be caused by moisture getting on it and freezing it so it wont close or by a failure in the electrical circuit that controls it. There was a service bulletin from about 3-4 years ago about defective control assemblys. I have replaced several and as far as I know Frigidaire is still replacing some of them for free if they fall under the model and serial numbers that were affected.
You can tell if it is frozen by turning the controls off and thawing the damper at the upper left rear of the fridge section with a hair dryer.. After you have it thawed out, turn the controls back on and you should hear the damper door motor running. Keep your thermometer in it and check it after a while and see if it shuts off before it freezes.
Post back with the complete model and serial numbers and I will try to locate the service bulletin at my shop computer tomorrow.
