Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
Posted on Apr 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Autofocus will not work,
NIKON DX 18-55
flash pops up, but shutter will not fire.
which I switch the lens setting to M it fires but is blurry
  • 1 more comment
  • cfranz May 09, 2008
    My autofocus wont work either. I set it to M and it comes out blurry. Also sometimes when I take pictures it flips the image!
  • skz712 Sep 27, 2008
    I have the lens in Auto mode and the camera still will not focus automatically.
    The pictures come out blurry.
  • jfbmesa Oct 01, 2008
    Just recently my camera stopped taking pictures. It doesn't autofocus (and yes I have it set to Auto) and the picture doesn't take. Today while everything was quiet, I tried again. When I press the shutter button and I here a clicking noise.
Anonymous
Level 1:
  • Contributor 34 Answers
  • Posted on Oct 10, 2008
Anonymous
Contributor
Level 1:
Answers
34
Questions
0
Helped
9648
Points
46
The d40 takes a while to focus, make sure the subject is centered on any of the 3 focus brackets.next press the shutter halfway and wait until the camera beeps , when it does, press it all the way and the picture will come out crisp.
Anonymous
Level 2:
  • Expert 111 Answers
  • Posted on May 17, 2008
Anonymous
Expert
Level 2:
Answers
111
Questions
0
Helped
60673
Points
257
Camera wont let you take a picture until focus is locked, why are you using M (manual focus) if you expect autofocus to do it for you? In M mode it is up to you to focus correctly or camera will not take the picture.
Why when i press my shutter halfway it does not focus ?
Make sure the A-M switch on the lens is set to A for autofocus.
Also make sure the AE-L button is set to on (pg 144 of your manual) in your menu's otherwise the half-press of the shutter won't allow it to focus.
Nikon d5100 Blurry photos When I take photos of a party, at night, my photos are very blurry. How can I fix..
Use autofocus if you have a AF lens on it.
Usually you get a kit 18-55 AF lens that has a A/M switch on the side. The switch should be facing the A side so it's set on autofocus. Then you have 9 points on your viewfinder, those are the autofocus points. It should usually be set to center, because you usually want the object in center of your photo to not be blurry.
Remember to press the shutter button halfway and give some time for the autofocus to focus. Then you can press it all the way, you should have your photos nice and clear.
If you happen to have a manual focus lens, you should be watching through the viewfinder and turning the focus ring on the lens and determine if your object is in focus. It's hard at night, but get some practice at home when you have some more light so you get more familiar with the focus.
2answers
Nikon D60 does not work in autofocus
Do you have access to another camera? If you do, try the lens on that camera. If you get the same results, it's the lens. If no, then it's the camera body. Once you isolate the problem you'll know if you need to get the lens fixed or if you need to get the camera fixed.
1helpful
Nikon d3000 autofocus issue
you should change the focus lock to AF-S, instead of AF-C
1helpful
My Nikon D200 just started locking when I depressed the shutter. It gave me the R25 reading in the view finder. If I depress the ae focus lock it fires. What is going on? [email protected]
Check your Custom Setting Menu, a1-a10:AUTOFOCUS.
Press Menu, select the Custom Menu Setting (looks like a pencil).
Select "AUTOFOCUS" and move to right.
a1 AF-C Mode Priority. Set to "Focus"
a2 AF-S Mode Priority. Default is "Focus", change this to "Release". This will enable the camera to fire anytime you press the shutter, regardless of if it's in focus or not. Use this setting if your having problems locking up, especially using some different lenses.
Try these settings. They may work for you.
Dropped my Nikon D60 now pictures are blurry and shutter moves slow
hello, mount another lens and check? this will indicate if the the problem with body or the the lens? check if af is on?
look if the mirror has got misaligned, if it has got slightly misaligned fire the shutter at slow speeds this will set it right.
hope this solves the problem
Aug 23, 2009 • Photography
1helpful
Automatic focus not working
The D40x only autofocuses with the latest AF-S (and old professional AF-I) lenses. Most traditional (screw-type) AF lenses from 1986 through today will not autofocus on the D40x. If your lens says "AF-S," you're fine.
Most lenses sold today for the D40x are AF-S, and so is the included 18-55mm kit lens. Many non-Nikon lenses from Tamron, Tokina, Quantaray, Sigma and anyone other than Nikon still won't autofocus on the D40x. Try before you buy, but honestly, there isn't much the included 18-55mm lens won't do.
Autofocus systems are fast, but not usually instantaneous. You have to hold the shutter down halfway as you compose the first shot so the AF system can focus and lock, and then the camera fires instantaneously when you press the shutter the rest of the way. See Preventing Shutter Delay for more.
1helpful
Every time i take a picture with my nikon d-40 the pictures are blurry. the camera is on auto focus but i can't seem to get the picture to come out clear. any suggestions?
Is your shutter speed fast enough? If not, you'll need a faster shutter speed or a tripod.
Are you using the proper focus sensor? Is the entire image blurry or just portions of it?
What happens if you focus manually? If it comes out sharp, then there's a problem either with the lens or the autofocus system on the camera. Have you tried it with a different lens?
Is the AF switch on the lens set to A?
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
Will not auto focus
"... Autofocus Lock ("AF-L"). Pressing the AF-L (Autofocus Lock) button enables the Nikon F4 to lock the focus. Simultaneous lock of AF-L and AE-L is possible. "'FREEZE FOCUS" - is another great function in the F4. It allows automatic shutter release when subject enters a pre focused distance - available with Nikon MF-23 and/or the 250 exp. MF-24 Multi-Control Back. i.e. with the shutter button fully depressed, the shutter is automatically fired when a subject comes into a preset manually focused position. This function is recommended for sports races because the racing course is usually known beforehand. It also works well in wildlife remote control photography, scientific, forensic and other technical photography. ..."
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
