Remove paper output tray extension (if installed). At each end of the slot where the tray extension fits there are tabs inside of small holes that release the top cover. The tabs can be pried up with a screwdriver inserted into the holes. See How to replace Fuser Assembly: HP Color LaserJet 2600n printer - YouTube at time 1:40. This will give you access to the paper jam.
I want to ask u one thing how this problem occure any bdy hv open the fuser if so then check the o/p bin flaps stucks inside open & refix them ur problem hv resolved
Top
Paper jams inside the printer
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
