All 3 phones says no range, and I can not access my answering machine, none of the buttons work. The letters LL flash on the answering machine.
SOURCE: cordless receivers not working
If you have tried the phone base unit in the same jack that works correctly with your answering machine and you still cannot break dial tone, then you have a defective base unit. Jer
SOURCE: CANNOT DIAL NUMBER--HAS DIAL TONE---ANS
What this indicate means that your phone have been over power.
What you need to do to solve the phone problem is to carefully put off the the phone for some time allow it to relax it self for above five minute then put it on again.
NOTE DO NOT OPERATE THE PHONE IN ANY FORM ON TILL IT LOAD UP TO IT FINAL CAPACITY.
Then you start to operate your phone again and it will resond to your command.
Thanks for using fixya.
REMOTE ACCESS
This section explains the remote access process for use with any touchtone
phone.
1. Dial the phone number for the answering machine.
2. After the answering system answers, press any numbered key on the
touch-tone pad to bypass the outgoing announcement, or wait until
the announcement finishes.
3. Enter the security code after you hear the tone.
4. Follow the voice menu to use the answering machine's remote functions.
The remote feature enables you to perform the following functions:
To Press this button
Review message 1
Play back messages 2
Stop message play back 2
Erase message 0
(during message playback)
Skip message 3
Turn off/on answerer 4
Review voice menu options 7
No valid dialing tones for 15 seconds will hang up the telephone line.
You can get the manual on the link below if you need page 31.
http://www.home-electronics.net/USER-GUIDES/26976_DOM_ES_CL_IB.pdf
Good luck
I have the Model 28112 cordless phone, and the handset says " out of range".
I have tried un plugging, waiting, and then starting over from the manual but no help. What is wrong? It says this as the handset is sitting on the base, so I know it is not because it needs to be near the base!
On my model 28112 phone, the handset says "out of range". It is sitting on the base, so I know it does not need to be near the base! I have unplugged the phone, waited, and started from the beginning but it still does not work. Help!
