Cameras Logo
Anonymous Posted on Jun 17, 2010
Reference Kodak P850 digital Camera I need
Reference Kodak P850 digital Camera I need detailed instructions on how to replace the LCD screen on this camera. Even better, would be complete disassembly instructions for the whole camera. George
  • 5 more comments
  • Anonymous Jun 17, 2010
    I need detailed instructions on how to remove the back cover
    I appreciate your efforts so far. However both experts that have replied have directed me the same on-line manual which I already have. This manual does not cover repair procedures.
    What I need is for someone to give me detailed instructions on how to remove the back cover. I have removed all visible screws, however the cover will not come away from the body. It appears to be held by the hotshoe and I need to know how to proceed.
    George
  • Anonymous Jun 18, 2010
    As I stated before I have the users manual and it doesn't supply the information I require.
    I need help from someone who has had experience removing the back cover of the kodak P850
    Thanks
    George
  • Anonymous Jun 19, 2010
    I am still looking for the answer regarding "how to remove the back cover of the Kodak P850 camera.
  • Anonymous Jun 20, 2010
    I still remain hopeful that someone can tell me how to remove the back cover on the Kodak P850 camera.
  • Anonymous Jun 24, 2010
    There must be an answer out there?
  • Anonymous Jun 25, 2010
    This is not a case where the cover is sticking a bit. The cover is definitely being held at top in area of the hotshoe.
    Perhaps I should be asking how to remove the hotshoe itself.
FIKRET UNALIR
Level 1:
  • Contributor 239 Answers
  • Posted on Jun 17, 2010
FIKRET UNALIR
Contributor
Level 1:
Answers
239
Questions
0
Helped
65956
Points
5
There is no such a book. But I thought you will need at least a detailed manual. And this is a very good manual indeed. You can download it from this link.
I hope it helps.
  • 1 more comment
  • FIKRET UNALIR
    FIKRET UNALIR Jun 17, 2010
    Did you try to look at the Youtube.com Youtube is not working in my Country now. So If I could look at this site you could get some help from there. Try to find a clue from there. I have never open this camera before. But tens of other brands. So I could not help you. I hope your problem will be solved soon. I am very sorry that I could not help you.
  • FIKRET UNALIR
    FIKRET UNALIR Jun 18, 2010
    As I said before I could not find such book.If only I could find. Also My experience is not related to this old model. Thank you.
  • FIKRET UNALIR
    FIKRET UNALIR Jun 21, 2010
    I am sorry that I can not help you. Thank you for your vote!
Anonymous
Level 3:
  • Master 1,049 Answers
  • Posted on Jun 25, 2010
Anonymous
Master
Level 3:
Answers
1049
Questions
Helped
286731
Points
2705
I believe with this camera, even after you take all the screws out it has a snap lock on one corner you will almost have to break to get apart. Very few people should do this type of thing themselves and it will void the warranty when you do.
After the camera is apart the screen will come free, there is a ribbon cable that attaches it to the unit that you will have to unplug and thread free to get out. Then you need to take the frame for the LCD apart. This has one or two screws and more snap locks.
Then the screen itself just sets in the frame and has a space for the ribbon cable to the side. The whole thing is really fragile so you would need to be freaky careful when you snap it apart and through the whole process of re-threading this cable back through the frame of the LCD and the unit itself.
Honestly, I could try and find you a break-apart, but I would personally be very reluctant to do this repair myself.
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Jun 24, 2010
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3737500
Points
36074
Www.youtube.com/watch?v=iErgIuZKTZQ
Here is a video that will show you how to take it apart in 30 seconds.
You will need to remove all the screws, slowly pull the camera apart, Slide the ribbon cable from the screen out of the slot, Pull the screen slowly out of place. (it is held on by a little adhesive)
Anonymous
Level 2:
Genius:
  • Expert 1,040 Answers
  • Posted on Jun 18, 2010
Anonymous
Expert
Level 2:
Genius:
Answers
1040
Questions
6
Helped
289953
Points
144
Sorry to say that But there is no such information uploaded by any expert on websites. I was also searching for repair manual 4 months ago. I spend my complete 2 months but does not get anything. and Finally get it serviced. So I personally thinks that don't waste much time to get repair instructions...
Thanks.
Anonymous
Level 3:
  • Master 4,889 Answers
  • Posted on Jun 20, 2010
Anonymous
Master
Level 3:
Answers
4889
Questions
8
Helped
1512910
Points
14106
The only thing that connects the display to the board is a ribbon cable called TFT PCB connector. You have to remove the rear cover to access it. Remove the screws securing the rear cover and disconnect the TFT cable. It is a rather tricky one. There is a black flap kind of thing holding the cable you should should lift the black flap upwards and then remove the cable.
Everything else is pretty straight forward as I do not think the SB-pop up should be tricky on this but if you run into trouble then get me an image and I will see you through it. Note that you may need to remove the PCB to get access to the LCD. Remove all connectors and remove the screws securing the lens and the lens itself if it is blocking your way. Also make sure you discharge the condenser near the flash. You don't want to get flashed by the residual voltage in the condenser do you? Anything else you find troublesome let me know and I will help you do it.
  • 1 more comment
  • Anonymous Jun 21, 2010
    Thank you for you comments.
    My problem is that I cannot get the back cover to come off. I have removed all screws that I can see (checked with magnifying glass). The cover bottom and both sides are free. However I cannot get the cover to come free at the top. Although I have tried to pry it loose (as much as I dare) it appears that the cover is being held by the "hot shoe" or something near it.
    Any ideas as to what may be holding it?
    Insert a small slice of paper(must be stiff) into the gap between the top cover and the back cover and slice it across the gap from one end to another while gently pushing the top cover upwards with the card.
    Rejectng it multiple times is not gonna make it any better. All it does is affecting my rating. I have put up with it 3 times but no more .See ya!
Tom Carson
Level 3:
  • Master 3,083 Answers
  • Posted on Jun 19, 2010
Tom Carson
Master
Level 3:
Answers
3083
Questions
0
Helped
684318
Points
8555
Usually, when searching the net, one can find a glimpse of light concerning a problem or issue. When you can't, there's always a reason. Having not dealt with this problem, I can only speculate why, and it makes sense. Removing the hotshoe will be tricky, since it has to be securely held, to support the flash. This will require either a pressure fitting to a secured base plate, and possibly a special tool to remove it. Most likely you're not going to get a direct explanation for this process since it is tricky, and also since it involves the flash and flash capacitor. There will be wires leading up to the hotshoe, and they will have a precise way of being loosened, or removed, again requiring specialized tools. Also, the possibility easily exists that one can become shocked by the flash capacitor, causing the camera to be dropped, and so it becomes a liability issue, and few would want to to be responsible for that circumstance, or it's consequences. I'm guessing here that the hotshoe is pressure fitted to a steel support bracket, which is in turn, screwed to an extension of the case, either preformed or spot welded or screwed to the camera body. It's has to be a precise-engineered assembly, and only going to come apart one way, without likely damage to the case, or wires inside. My suggestion is to find a camera repair shot that has done this, and go talk to them about it. They may explain, albeit on abbreviated terms, what is required, but it may give you enough of a clue to do it yourself. If you're patient, and a little political, you may glean enough to brave the process yourself. You may find a tech that will stick their neck out for you on this issue, but I doubt it, for the liability issues that could exist. Never say never, though, I always say. Good luck, and hope this helps!
  • Tom Carson
    Tom Carson Jul 09, 2010
    I've never taken apart this camera, but it makes sense that it's a tight, snap connection, since it has to anchor to the case securely. Like someone else said, without special experience or tools, it will be tricky to get apart. I would take it to a repair shop and see if they will just pop it apart for you, or tell you how. You might get lucky.
electronic & computer repair& servicre
Level 3:
  • Kodak Master 12,061 Answers
Kodak Master
Level 3:
Answers
12061
Questions
0
Helped
4007923
Points
36390
Http://www.retrevo.com/support/Kodak-P850-Digital-Cameras-manual/id/200dj381/t/2/
Above is your user manual
You will have to get a service manual, this is the only thing that has that information. I have searched the net, for one, but have been unable to locate one. You will most likely have to contact the manufacturer and ask for one.
I must advice though, that this is no easy task, it is very time consuming, from experience, and very very fiddly as well. Another problem that not having the service manual, is the not having the Part Number to order, a replacement part. As without that special number, one simply cannot order or find spare parts. in saying that however, I have found that Ebay, is a great source of spare parts, mostly second hand though. I would expect also that you will need a set of Torx Drivers too, as these are what one must use to remove the screws. A good magnifying glass is a great aid too.
In my professional experience, I would actually advice you to cut costs and guarantee repair, would be to contact, a local or head office of Kodak, and ask them for a referral to an authorised service center, you see these places use original parts, the engineers are trained on only those units, and they usually guarantee fast reliable repair. When, at the repair center, you can ask for a free "Quote" as to the cost of Replacement/Repair. That way, at least you can make an informed decision as to repair or replace the entire unit.
However if you really wish to proceed, then... perhaps the following will help.
I have effected similar repairs by purchasing another camera, the same type etc, that has some "Other" type of fault, dissimilar to the problem the one I am repairing, then I remove the "Good" components from the "Salvage" camera. But, usually, you still have to have a service manual though. Again, in saying that, I have tackled cameras "Blind" as it were, as long as you are careful, usually if you locate all the screws etc, it sort of "Falls apart" or at best, a thin, knife of plastic will usually pop the case apart, NEVER force it. Then it is just a case of burrowing into where you wish to go, Now I usually draw, as I go, noting cables, settings etc, so when you go to put it back together it is all documented.
    Thank you very much for your comments (sage advice). I am technically inclined (automotive technician) and have puzzled over this problem for a few days now. I have removed all visible screws (checked with magnifying glass) however the cover is still being held in the area of the "hotshoe" and I'll be damned if I can figure out how to solve it. I suspect that a part needs to be pried up .............. the trick is what part and how much force to use
    As you said don't force it.
    Anyway I appreciate your taking the time to respond I guess I am just venting my frustration.
    Cheers
    Senueh
Anonymous
Level 3:
Genius:
  • Master 1,689 Answers
Anonymous
Master
Level 3:
Genius:
Answers
1689
Questions
8
Helped
567672
Points
4681
This may not have illustrations but you have a baseline on which part to loosen before disassembly.
http://www.instructionsmanuals.com/u2/pdf/camara_foto_digital/Kodak-P850-en.pdf
When I turn on the camera it start doing a random flash on the LCD screen
took the memory card out and try . If u face same problem then reset the camera and then try. If the result same then you need to visit service center for firmware reinstalling. Thank you
1helpful
2answers
My Kodak EasyShare P850 Digital Camera won't turn on
Spray a littlebit of WD40 or contact spray round the powerswitch, after removing the batterie and work the switch a number of times.
Can I use my Kodak P850 as a webcam
No sorry it's not possible to use any camera model as a webcam.
Keeps showing on screen, "camera error # "
If this camera just show blue screen it means that the LCD or he mainboard of the camera is defective., is this error code display also a number., usually it will also display the error code number.
If you have this error code please call tech support toll free 1 800 235 6325 and send the camera for repair
2answers
My P850 Kodak camera turns off / on in
P850 is no longer repaired since no longer produced.
If under warranty they will exchange you camera to a brand new one.
If not under warranty KODAK offeres a Trade up. You can chose any new model available in stock and receive 25-30% off.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
3helpful
Easy Share P850 lost eyecup
According to Kodak, the rubber eyepiece is not available for purchase, you have to send it to them to get it fixed...I would try to take it to a local camera repair shop and let them do it.
KODAK P850
hi sir
please find whether the memory card is corrupted..
Kodak p850 Help!! error code
also having same problem after 18 months of no problems. As well, camera will not read memory cards which I have used in this camera almost since new. Format card, still no read. Sometimes when I take first photo, lens retracts as though camera is powering off but then changes it's mind and is o.k.
2answers
Lcd screen comes up in spots
Once your LCD has gone blotchy, that means its probably time to get a new one. Water has either leaked inside and ruined it or there is damage in the wiring. As for opening your camera, once all screws are out, it usually a matter of clips on the inside that snap the 2 halves of the camera together. I don't own this camera so I would suggest using a small flat head screwdriver and gently prying around trying to find the clips.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
