It very well is the door switch might be stuck. The way to unstick it is to slam the door. Very often it'll jar the switch loose if that doesn't work you'll need to order one. Easy to install there are youtube videos on it. If you need the part...try here...repairclinic.com or appliancepartspro.com.
Hope this info helps a little.
SOURCE: Door Lock LED flashing
The solution from testy helped me but I decided to change it.
I cut the plastic latch away from the end of the interlock,just the little bar that holds the door closed.This means that the lock position doesn't affect the door.
I then used the little piece of plastic to act as 2 packing pieces to hold the lock half closed. This works fine.
Don't push the lock fully closed or it doesn't work
SOURCE: Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
SOURCE: WMA 54 Hotpoint Aquarius washing machine lights flashing
the problem here is the machine is not emptying when its supposed to, you will find it is stopping at the rinse cycles. there is a sump underneath the machine that needs to be emptied. From my experiences, 9 out of 10 hotpoints that i would of repaired with the same problem as you are having is usualy caused by using the color catcher sheets, they are a disaster.
[email protected]
pallesappliancerepairs.com
SOURCE: Wash starts it fills with water then stops and wont wash
when i put my hotpoint aquarius extra wma44 on iy flls with water and then the door lock light comes on....when it has filled with water the machaine will not do its wash...ive changed the door lock unit inside hoping that will fix it but when i switched it on again ...it done it again...can anybody help to see what ive missed out
