Computers & Internet Logo
A
Anonymous Posted on Jun 17, 2010
My cd/dvd device is not working...i have had no trouble up until this: When I ask to fix the problem I get this message:windows can not load the device driver for this software. The driver may be corrupt or missing (code 39)
Anonymous
Level 2:
Sergeant:
  • Expert 195 Answers
  • Posted on Jun 17, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
195
Questions
0
Helped
56061
Points
588
Please run the Fix It on this Microsoft Knowledge base article and it should resolve the issue for you.
http://support.microsoft.com/kb/982116
Robert from Blitware
TEAC CD/DVD problems
Hmm, sounds different to the usual problems I've come across but try this:
Paste the following into a new text document and "Save As..." type "All Files (*.*)" and call it "DVD Fix.bat"
@ECHO OFF
REG DELETE "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}" /v "UpperFilters /f > NUL
ECHO Press any key to restart the computer.
PAUSE > NUL
Shutdown.exe -r -t 0 -f -c "UpperFilters reg key removed to fix CD/DVD-ROM" -d p:2:3
Run the file and restart your computer when prompted.
If you're trying to write to a blank disc, make sure in the drive's properties that you have recording/burning enabled. If you do, try re-installing your CD/DVD burning suite. If you didn't have one, try a system restore.
If this doesn't work or you've disable system restore, you can go into hardware manager and roll-back the driver. If you don't have a roll-back available. uninstall the driver and restart your computer. A default Windows driver should then install.
Check the drive is physically performing - does it load/eject the disc? Does it spin-up? Are you able to read any discs?
I you have any further problems, it would help if we had the model name of your laptop.
1helpful
Hi, The DVD/CD Rom Icon has dissapeared on My Computer. When I go to control panel - device manager and click on the dvd/cd rom drive icon I get the following message in the genaral...
You will need to re-install the driver. Right click the device in device manager and select properties. Navigate to the driver section and uninstall all existing drivers. (It may *not* give you the option to do that, depending on how corrupted the driver is, but it should.)
Reboot the PC.
Upon reboot, Windows should find the new device and install generic drivers. It will probably ask you to reboot a second time.
The cd/dvd writing drive has stopped working on our HP computer with Vista windows. we checked the hardware on control panel and it said the drive was working. Help.
Well, that only means that the device is getting electrical power, and the "data" cable between the device and the motherboard is connected, and that Windows has loaded the correct device-driver for the device.
It does NOT mean that the LASER inside the drive is working correctly -- it's possible for the LASER to have stopped working.
Spend $40, and buy a new CD/DVD reader/writer, to replace the "dead" unit. This is cheaper than paying a technician $25 to $50 to try to trouble-shoot "hardware" problems inside the drive.
1helpful
3answers
My DVD rom drive is not working I cannot "see" it on the system I have this error message "windowns cannot load the device driver for this hardware. the driver can be corrupted or m missing error code 29...
Check in device manager. To do this. 1st right click my computer, 2nd Click properties, 3rd click hardware, 4th click Device manager, 5th check that the computer is seeing the DVD/CD-ROM drives by double clicking the DVD/CD-ROM drives words or click the + symbol next to DVD/CD-ROM drives, the drop down menu will list your device if it’s there. If a device is listed double click the device. If it says it’s working properly click driver in the top bar and uninstall, then re-boot, the system will re-load the driver on re-booting. If the driver was corrupt it will re-install it correctly.
If the system cannot find the driver on re-booting it's missing from the systems file, go to the Support Fujitsu site and download and install the driver. Its free all you have to do is put the laptop details in the appropriate boxes and all the drivers for that laptop will be listed.
From your description of the error message it’s no doubt a corrupt or missing driver.
Hope this helps.
Cleaning my files, accidentally lost drivers for my Pioneer DVD-ROM DVD-117R, also Pioneer DVD-RW DVR-104....driver 5.1.2535.0 System restore could not take me back far enough, and cannot load Recovery...
BAD DVD
Windows 7
To resolve this problem on a computer that is running Windows 7, use the Hardware and Devices troubleshooter. For more information about how to open this troubleshooter in Windows 7, visit the following Microsoft Web site:
http://windows.microsoft.com/en-us/windows7/Open-the-Hardware-and-Devices-troubleshooter
Back to the top
Windows Vista
Click Start, and then click All Programs.
Click Accessories, and then click Run.
Type regedit, and then click OK. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
In the navigation pane, locate and then click the following registry subkey:
In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
On the Edit menu, click Delete.
When you are prompted to confirm the deletion, click Yes.
In the right pane, click LowerFilters.
Note If you do not see the LowerFilters registry entry, unfortunately this content cannot help you any further. Go to the "Next Steps" section for information about how you can find more solutions or more help on the Microsoft Web site.
Exit Registry Editor.
Restart the computer.
Now go to the "Did this fix the problem?" section.
Back to the top
Windows XP
Click Start, and then click Run.
In the Open box, type regedit, and then click OK.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
Back to the top
Windows 7
Click Start, click Computer, and then see whether the drive is listed.
Windows Vista
Windows XP
Click Start, click My Computer, and then see whether the drive is listed.
Back to the top
Is the drive listed?
If the drive is listed, try to play or access a CD or DVD.
If you can play or access a CD or DVD, you are finished with this article.
If you cannot play or access a CD or DVD, you may have to reinstall some programs. Some programs might not be able to use your CD or DVD drive until you reinstall those programs. If the problem occurs again when you install or uninstall those programs, contact the manufacturer of the program to see if an update is available that solves the problem. Some examples of programs that might be affected are:
iTunes software by Apple
Nero software by Nero Inc
Roxio Creator software by Sonic Solutions
Zune software by Microsoft
After reinstalling your programs, if you can play or access a CD or DVD, you are finished with this article.
If you still cannot play or access a CD or DVD, please see the "Next steps" section.
If the drive is not listed, remove and reinstall the existing drivers.
Back to the top
Remove and reinstall drivers
If the drive is not listed, remove and reinstall the existing drivers. To do this, follow these steps:
Windows 7
Click Start, and then click Control Panel.
Click System and Security, click System, and then click Device Manager.
Note If Control Panel is in Classic View, double-click System, and then click Device Manager.
In Device Manager, expand DVD/CD-ROM drives, right-click the CD and DVD devices, and then click Uninstall.
When you are prompted to confirm that you want to remove the device, click OK.
After the computer restarts, the drivers will be automatically installed
Windows Vista
Click System and Maintenance, click System, and then click Device Manager.
After the computer restarts, the drivers will be automatically installed.
Windows XP
Click System and Maintenance, and then click System,
On the Hardware tab, click Device Manager. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
See if reinstalling the drivers fixed the problem.
Now try to play or access a CD or DVD.
If you cannot play or access a CD or DVD, please see the "Next steps" section.
Back to the top
Next steps
If this method did not help you, you might want to use the Microsoft Customer Support Services Web site to find other solutions. Some services that the Microsoft Customer Support Services Web site provides include the following:
Searchable Knowledge Base: Search technical support information and self-help tools for Microsoft products.
Solution Centers: View product-specific frequently asked questions and support highlights.
Microsoft Product Support Newsgroups: Contact counterparts, peers, and Microsoft Most Valuable Professionals (MVPs).
Other Support Options: Use the Web to ask a question, to contact Microsoft Customer Support Services, or to provide feedback.
If you continue to have questions after you use these Microsoft Web sites, or if you cannot find a solution on the Microsoft Support Services Web site, click the following link to contact Support:
http://support.microsoft.com/contactus
Back to the top
More information
This issue may have occurred after one of the following situations:
You upgrade a computer to Windows Vista or install Windows Vista Service Pack 1.
You install or uninstall CD or DVD recording programs.
You uninstall Microsoft Digital Image.
You may see one of the following error messages:
One of the following error messages appears when you view the CD drive or the DVD drive in Device Manager.
Error message 1
The device is not working properly because Windows cannot load the drivers required for this device (Code 31).
Error message 2
A driver for this device was not required, and has been disabled (Code 32 or Code 31).
Error message 3
Your registry might be corrupted. (Code 19)
An "error code 39" error message.
A message that resembles the following appears in the notification area:
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
2helpful
2answers
Code19 on sony cdrwdvd willnot reconize on inspiron 1525
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program or Windows Vista.
  • You upgrade a computer to Windows Vista or install Windows Vista Service Pack 1.
  • You install or uninstall CD or DVD recording programs.
  • You uninstall Microsoft Digital Image.
  • One of the following error messages appears when you view the CD drive or the DVD drive in Device Manager.
    Error message 1 The device is not working properly because Windows cannot load the drivers required for this device (Code 31). Error message 2 A driver for this device was not required, and has been disabled (Code 32 or Code 31). Error message 3 Your registry might be corrupted. (Code 19)
  • An "error code 39" error message.
  • A message that resembles the following appears in the notification area: Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
  • you can find this information and more at this site..
  • http://support.microsoft.com/kb/314060
CD/DVD burner stopped working
I had the same problem on my Sony Vaio and I found a free program called "CD Tray Pal" You just click on the desktop icon and it loads and windows recognizes your drive. Amazing, after a while, it fixed itself and I did not have to use it anymore! Hope this helps. http://www.e-systems.ro/ You should be able to find it on this site.
1helpful
CD / DVD player not listed as device on Windows Explorer
Try physically removing the player and fire up the laptop. Power down the laptop, replace the player and power back up. If that doesn't help, see if BIOS recognizes it.
If that doesn't work, get back to me.
Ron-
Grand Canyon Tech
Grand Canyon Tech
