Apple iPod MA446LL/A MP3 Player Logo
Posted on Jun 17, 2010
My 30gb classic ipod has a sad face and does not charge
Anonymous
Level 1:
Filmmaker:
Uploaded 5 video answers.
New Friend:
  • Contributor 26 Answers
  • Posted on Jun 17, 2010
Anonymous
Contributor
Level 1:
Filmmaker:
New Friend:
Answers
26
Questions
0
Helped
5656
Points
49
Check out this step by step solution, it may help? http://support.apple.com/kb/TS1373
Is your ipod covered under warranty? If so following the process above and get it into the Mac store, if it's not check out this company...whiteboxservice.com. White Box fixes broken ipods out of warranty.
2 Related Answers
Anonymous
  • 6 Answers
  • Posted on Jun 12, 2009
SOURCE: my 30gb ipod still shows the sad face without the hardrive
hard drive
Anonymous
  • 6 Answers
  • Posted on Jan 08, 2010
SOURCE: iPod 30gb
Re-boot
30 gb ipod has sad face and low battery icons
could be bad charger or time to replace the battery. lots of places sell new ipod batteries.
does it work if you leave it plugged into your computer for a few hours? if it does not then its a bad abttery.
IPOD 30GB Video 5th Gen will not Power ON
sadly it's dead...go to apple.com and buy a refurbished unit or ebay.
1helpful
3answers
My ipod classic has a sad face on it and it won't trun on..can you help me
Listen to the iPod - if you don't hear the hard drive spin properly and evently when it starts up you may have a hard drive issue. If it doesn't spin at all, you may have a logic board issue? Here is a ipod repair guide on how to dismantle and iPod classic.
My ipod 30gb shows its sick face on start up help
This is generally caused by a hardware failure. If it's under warranty, send it back to Apple. Otherwise, you need to start looking at replacing the hardware. If the screen shows a sad face, then you can assume the screen and battery are probably OK. So, the problem is probably with the hard drive or the logic board.
1helpful
30gb video has sad face and low battery and will not charge even
Don't just change the hard drive,Change the motorboard as well.Different generation ipods use different boards and the hard drive from one won't always just plug in and work.
3answers
IPod won't charge and has sad face
Unhappy face
http://www.zolved.com/synapse/view_content/19230
I have been told this is because the speaker wires are pushing against the laser motors. How can I fix this?
Sad face icon
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
