Cars & Trucks Logo
Posted on Jun 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I change the gearbox oil on tr4a. 10 miles later, it will only engage 2nd gear. any ideas
Anonymous
Level 3:
Brigadier General:
  • Master 4,044 Answers
  • Posted on Jun 17, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
4044
Questions
0
Helped
1244386
Points
12252
Standard shift? I assume this as it is the most common version. No matter, Check your fluid level. If it is a standard shift you may need to adjust the clutch and or throw out bearing.
1helpful
Mazda bravo b2600 gearbox growles and grumbles. cant select 2nd or 4th gear. 1st, 3rd,5th & reverse ok.
I am sorry to tell that the gearbox need to have some major repair. It is also not advisable to continue driving as the gearbox can breakdown completely leaving you stranded. At least one the cluster drive gears in the gearbox is damaged (gear tooth stripped off) that will result in that only some of the gears being able to be selected. The broken off tooth are still in the gearbox and due to the oil movement in the gearbox it can be "washed up " in between to engaged gears destroying those as well. This will happen up to the point where there are no gear selection at all.
Gear shifting problems in Honda Prelude with Automatic transmission only when gearbox is cold
While just change ATF oil or CVT oil in transmission & old filter too. your car problem will be solve....
2helpful
Gearbox engagment
i cant solve this i got the same problem did u ever solve this. i have changed - clutch,slave an master cylinder and the gearbox has been rebuilt
1helpful
Iv bought a rover 45 saloon 2.0 v6 and iv got a gearbox problem. the car has only done 53,000. when i drove it about 10 miles, i came off motorway slip road and came to a junction and had to stop. it was...
Sounds like the gearchange friction bands or actuators are sticking, but the solution is probably to change the gearbox oil - maybe more than once - to clean up the gearbox. This can produce miracles, as all the sliding hydraulic actuators depend on it.
6helpful
4answers
2003 mercedes C270 CDi auto gearbox fault
mercedes c220 cdi 2004 140k done gets stuck in gear then have to turn of ignition to get it working again. had recently had the gearbox serviced
2helpful
2answers
Prelude 2.2 vti W reg auto automatic tiptronic gearbox slipping
Hi there. Although the Dealer has changed the oil, did they do a 'Stall Test' whilst the gearbox was cold and again when at normal running temperture? If not, that's what they must do firstly. This will identify whether you have a slipping clutch/s. The Honda autobox also includes what is known as accumulators - these control how each clutch is engaged during acceleration. For example, if you are accelerating slighly/smoothly, you want each gear to be engaged gently and smoothly, whereas, when accelerating hard, you need the gear engaged quickly and hard to aviod clutch slippage. Thus, the fact that you are experiencing a hard engagement might mean that an accumulator/s is seized. If that's the case, it will mean that the autobox will need stripping, cleaning and be checked for worn components. Hope this helps, Scottech.
Top Triumph Experts
ZJ Limited
ZJ Limited
ROBERT GARCIA
ROBERT GARCIA
Ngoro
Are you a Triumph Expert? Answer questions, earn points and help others
