Check if your memory is full either phone memory or your memory card and check if where your recorded video will be stored after recording. either the phone memory or memory card if any of them is already low in memory space you really can't start video recording if you don't have enough memory for you to store the video you want to record..Hope it will help you.
You can connect your phone to a computer and transfer the recordings to your computer. You can also buy a memory card with more capacity. Your phone supports up 2GB(Micro SD card).
Insert your memory card into your computer's reader if you
have one. If
not, you can purchase a multi-format USB Memory Card reader from
Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available
drives.
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a
non-reversible process so make sure this is what you truly wanted to do
in the first place.
6
Once the process is completed, take the memory card out and insert it
into your Digital Camera or any other device. Try to browse to it to
make sure it works fine now.
i have buy a new Nokia N73 music addition.
but when i put a password on my memory card, it didnt act.
it accept the password, but still the memory card open without password.
the problem Probably is that the memory card isn't the right kind, so it just records to the "Built in memory". The only way to fix this is to format the Memory card
Seems like its time to flush the contents of the memory card of camcorder to a computer. There's a limited amount of memory in every memory card. After constant recording, the memory gets full and the recorded stuff needs to be either deleted or flushed (uploaded to a computer) to make room for newly recorded stuff.
Unless you have a blank memory card, your problem should be solved by the above mentioned idea.
