A
Anonymous Posted on Jun 16, 2010
Hello i cannot enable the bidirectional
Hello i cannot enable the bidirectional communication because the check box is not available
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
400
Points
I had the same problem you have to goto the tab that says "Ports" and it is at the bottom of the dialog box right above enable printer pooling.
2helpful
Trying to print to a dell photo aio printer 964 from my laptop and it keeps telling me "communication not available; the printer cannot communicate with the computer; please turn on enable...
Bidirectional Printing - A means of printing by a computer printer which prints one line from left to right, then the following line from right to left. Such printing is faster than printing in one direction only, as there is no need to wait for the carriage or other imaging mechanism to return to the left margin before starting a line.
how to enable bi-directional printing.here's how:
  1. -click on start
  2. -click on printers and faxes (control panel->printers and faxes)
  3. -right-click on Dell Photo All in One Printer 964 All-In-One icon
  4. - click on properties
  5. -click on ports tab
  6. -down at the bottom there's a small box before bi-directional support
  7. -tick the box to enable it then click apply,ok
  8. -try printing again
note: in vista , printers and faxes is printers.in win 7 ,it's devices and printers.
and properties in win 7 is printer properties
Keeps telling me to enable bidirectional communication
Hi:
When you first loaded the print driver there should have been a box to check to enable bidirectional communication. Most Lexmark printers require this to work properly
Andrew.
How do I Enable bidirectional communication on a dell 924 printer? Thanks
Go to Start
Control Panel
Printers
Right click on your printer, left click Properties, left click Ports.
Make sure to check the box Enable Bidirectional Support. (Enable Biodirectional Support)
CANT ENABLE BIDIRECTIONAL COMMUNICATION X4550
I have tried to set up this wireless printer on my laptop (windows vista basic). I run through installation and get message - installation complete and the green indicator light is fully on. When I try and print I get message Printer cannot communicate with computer - please turn on 'Enable Biodirectional Communication' in printer properties. I go to control panel/printer/propertie/ports/ and I see Enable Biodirectional communication - the box is grayed out and I cannot enable it. Any suggestions?
When i go to print i get an error message saying that i need to enable bidirectional communication. How do i do this?
Enable Bidirectional Support Go to Start
Control Panel
Printers
1helpful
Last week I installed Windows07 and now my Lexmark printer series 3400 will not print. I keep getting this message: Please turn on Enable Bidirectional Communication setting in tne properties dialog. ...
go to your "printers and faxes" screen. In windows 7, it may just be called printers. You should see your printer listed there. right click on the printer and choose properties. At the top of the next window, there will be several tabs. click on ports. you should see a box that says Enable Bidirectional Support. put a check in that box. If that does not solve it, then contact lexmark about a Windows 7 driver.
When trying to print says enable bidirectional communication
I came up with a work around solution and for $9.99 I'll tell youo how I did it......
8helpful
2answers
Lexmark X2500 is giving Bidirectional communication error message
Make sure that the "Enable Bidirectional Support" checkbox is checked: Go to "Control Panel"->Printers->Right click on the print Object->Properties under "Ports" tab, enable this check box if not already enabled. If you using vista make sure you do this from an "Admin" account, you may also need to select the "Run as Administrator" option after you right click on the "PrintObject".
72helpful
2answers
What it means Enable Bidirectional Communication caution spam number below
To enable bi directional printing:
Open Printers and Faxes in control Panel
Right Click on the Printers Icon
Select PROPERTIES
In the Properties dialog box select the PORTS tab
Near the bottom there is a check box to enable Bi-directional printing
Make sure it is checked
Click OK to exit the dialog box
I purchased a Gateway laptop p-series computor I tried to instal my 8300 printer I get the this message communication not available the printer cannot communicate with the computer please turn on...
If you have an XP OS, click START Menu then click "Printers and Faxes". A window will open with a list of printers installed in your computer. Right Click the printer icon for your 8300 printer then select properties. Go to "Ports" Tab, you will see the check box for "Enable bidirectional support".
k24674
ADMIN Andrew
ADMIN Andrew
