A newbie here..How Can I prepare a report to Word from Access File?
This from the Word Help files - search for Embed.
You can simply select an area in Excel copy it and paste it into your word document, but embedding allows the data in your Word document to be automatically updated as you change the figures in the Excel Worksheet.
From the Help pages:
You can insert objects (object: A table, chart, graphic, equation, or other form of information. Objects created in one application, for example spreadsheets, and linked or embedded in another application are OLE objects.) into a Microsoft Word document when you want to include information from files created in other Microsoft Office programs or in any program that supports linked objects (linked object: An object that is created in a source file and inserted into a destination file, while maintaining a connection between the two files. The linked object in the destination file can be updated when the source file is updated.) and embedded objects (embedded object: Information (object) contained in a source file and inserted into a destination file. Once embedded, the object becomes part of the destination file. Changes you make to the embedded object are reflected in the destination file.).
Embedded object
Linked objecreate a MS Word Report - default.aspx?assetid=za060474671033/default.aspx?assetid=za060474671033" alt="default.aspx?assetid=za060474671033" class="h_mi" /> Source file
For example, a monthly status report might contain information that is separately maintained in a Microsoft Excel worksheet. If you link (link: Used to insert a copy of information created in one program into a Microsoft Word document while maintaining a connection between the two files. When the information changes in the source file, the changes are reflected in the destination document.) the report to the worksheet, the data in the report can be updated whenever the source file (source file: The file that contains information that was used to create a linked or embedded object. When you update the information in the source file, you can also update the linked object in the destination file.) is updated. If you embed (embed: To insert information created in one program, such as a chart or an equation, into another program. After the object is embedded, the information becomes part of the document. Any changes you make to the object are reflected in the document.) the worksheet in the report, your report, or destination file (destination file: The file that a linked or embedded object is inserted into. The source file contains the information that is used to create the object. When you change information in a destination file, the information is not updated in the source file.), contains a screate a MS Word Report - default.aspx?assetid=za790050001033>The differences between linked objects and embedded objects
The main differences between linked objects and embedded objects are where the data is stored and how you update the data after you place it in the destination file.
Linked objects
When an object is linked, information is updated only if the source file is modified. Linked data is stored in the source file. The destination file stores only the location of the source file, and it displays a representation of the linked data. Use linked objects if file size is a consideration.
Linking is also useful when you want to include information that is maintained independently, such as data collected by a different department, and when you need to keep that information up-to-date in a Word document.
When you link to an Excel object, you can use the text and number formatting from Excel, or you can apply the formats supplied by Word. If you use the Word formats, you can preserve formatting when the data is updated. For example, you can change table layout, font size, and font color without losing those changes once the object in the source file is updated.
Embedded objects
When you embed an object, information in the destination file doesn't change if you modify the source file. Embedded objects become part of the destination file and, once inserted, are no longer part of the source file.
Because the information is totally contained in one Word document, embedding is useful when you want to distribute an online version of your document to people who don't have accecreate a MS Word Report - default.aspx?assetid=za790050001033sheets.
Edit and update linked objects
To edit a linked object in your document, use the Links command on the Edit menu.
By default, linked objects update automatically. This means that Word updates the linked information every time you open the destination file or any time the source file changes when the destination file is open.
If you prefer, you can change a linked object's setting so that the linked object is updated only when you choose to manually update it.
To ensure that your document is always up-to-date, you can also update linked objects whenever you print the document.
To prevent updates, you can lock individual linked objects. When you lock a link, Word uses the last information available from the source file.
You can also permanentcreate a MS Word Report - default.aspx?assetid=za790050001033inked object and its source file.
Edit embedded objects
To edit an embedded object, double-click it, and then make changes to it in the source program (source program: The program used to create a linked object or embedded object. To edit the object, you must have the source program installed on your computer.). If you don't have the source program, you can convert the embedded object to the file format of a program you do have.
