Go to control panel and printers, in properties for your printer, select printing options or preferences. Turn off
mirror image printing. It is used to print on a transfer sheet to transfer to t-shirts and such.
You have probably turned on the "Mirror Image" option.
When you go to print and the Print window comes up, select Preferences and then the Advanced tab. Look for the Mirror Image option and Disable it by clicking on the underlined option and change it.
(BTW, the Mirror Image is used to print iron-on images for t-shirts, etc.)
NOTE: If you don't see it on the Advanced tab, look on the Effects tab.
click on start > control panel > printers or printers and faxes >
right click on the printer icon and select printing preferences.
click on advance and look for mirror image
turn off mirror image and click apply.
this should work
Yes, you need to "MIRROR" the image. Go to printer properties and select the ADVANCED TAB. Click on the MIRROR setting then print onto the transfer paper. The image should print out backwards like you are looking at it in a mirror. When you iron it onto a shirt, it will come out correct.
When you select "Print" and get the print window to confirm....select "Preferences". On the Advanced or Effects tab, look for the "Mirror Image" menu item. Turn it Off. If you cannot find it, comment back.
(BTW, the Mirror Image option is normally used to print t-shirt transfers.)
this is when it is mirroring itself. Ours did this and we uninstalled and reinstalled the software and it worked fine after that. I don't know what else you could do I am sure some of the experts will but I do know this worked for us.
