Tip & How-To about Cell Phones
A Tip for your Blackberry 8220 !!
Today I ran into a Problem with my Blackberry 8220. I turned it on and it said to "INSERT SIM CARD". To my surprise I realized I never removed the sim card. At this point i realized because of this error , I was unable to make calls or sent texts or anything else...I was freaking out! After taking the battery and sim card out and restarting the phone several times, I still had no luck!"INSERT SIM CARD "was still there!!! I arrived at school turned on my laptop and searched google and found the great CRACKBERRY web site. After searching a bit I ralized this was a common issue with my phone. Someone suggested i try a piece of paper behind the sim card. This would allow the thin simcard to press against the spring inside for a better connection. First i tried a piece of copy paper I ripped and slid on carefully...Tried restarting and ther it was again"INSERT SIM CARD"..At this point I couldnt give up so i tried something thicker...a piece of cardboard from the back of my Managing and Maintaiining Microsoft Server 2003 Book. Its the card board that is at the back of the book where you find the supplemental CD/DVD. What made this even better was the fact that when i ripped a piece it had some adhesive on it so it stuck right on the sim card!! I tried it and ...it worked!!!!!!...So there you go...my Blackberry 8220 insert sim card TIP!!!!!
Cell Phones Logo
sim card error
If your Blackberry 8220 phone displays an error message saying "Sim card error" then your phone is probably sim locked.To unlock it,visit the site Unlocking4U.com here they are providing the permanent sim unlock code at reasonable cost with easy step by step unlocking instructions and unlock it.This is the easy and fast unlocking method.
Source:http://www.unlocking4u.com/blackberry-8220/rs5wp9/
I am trying to use an unlocked Blackberry pearl 8220 on AT&T, it won't find a signal
If you are getting an error message saying, "Invalid SIM Card" or "Incorrect SIM Card", then you would need to unlock the phone first.
Unlock Blackberry 8220 Pearl Flip
even after i reboot it it keeps saying invalid sim card
Remove your sim card, wipe it with a smooth dry cloth and insert it again.
If this doesnt work, contact your network provider and they will help you.
My signal keeps sayin SOS and it tells me to insert sim card when
1.check the sim card if it is properly inserted.or try other sim card.
2.did you turn on your wifi?turn it on to have a signal from your network.
3.Is it unlock/openline already?
4.if the above mention is still not working its already a hardware problem.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
