I have changed the Claris Filter many times before. This time the machine is stuck at "Fill System/Press Steam." The water tank is full. Each time I try pressing the steam button the system says "Please Wait." It makes at lot of the usual noises and then returns to "Fill System/Press Steam." Not a single drop of water has come out of the steam nozzle during this process.
I have had an S9 for 8 years now and have had it refirbished twice in its lifetime. I am convinced that the Claris Water filters cause this problem in that they can creat to much resistance or air and the system becomes water starved.Try taking out the filter and running steam for a couple of minutes. If you see water coming through, you most likely have a bad filter. moving forward, i am leaving the filter ourt and running the system in the DeCalc mode. I will have to decalcify the system routinely now but its worth eleviating the filter headache.
Probably have air in the system - it needs to be flushed, Run the tea portion hot water for a while. If not check the manual on how else to flush the system Gary
SOURCE: Changed Claris Filter-now says
Fill your water tank with Warm Water and then try a few times. Keep Patient and Keep trying for some times and it will work.
the fill water tank message won't go off
