Mcdevito75 here, First look for any for any notches or cut outs on the cover, there should be a cut out on the cover for the stem, at this point line up the cut out with the stem, place the watch on a sturdy surface, Table, counter top, make sure the watch is completely flat on this surface with the cystal (glass) faceing up, now place the palm of you hand on the crystal and with even pressure press down slowly and evenly, the back should snap on.
Place the watch face-down on a clean towel to protect the crystal.
Gently unscrew the backplate from the watch with a small jeweler's screwdriver and set it aside.
Locate the battery compartment and remove the screw holding the cover in place, using the screwdriver. The battery is a small, round silvery button.
Make a note of the battery polarity before you remove it. Is the battery positive (+) side up or negative (-)?
Take the battery with you to a watch shop or electronics store to buy a replacement.
Insert the new battery in the compartment. Replace the battery cover and reverse the above steps to reattach the back cover of your Peugeot watch
