Question about Bosch Exxcel WFX 3267 Front Load Washer
Machine selects a program fills up with water then does nothing, but still makes usual clicking noises. If drain is selected machine indicates 12 mins as normal starts to drain then shows 1 min and does nothing i.e drum does'nt turn or spin.
    Problem Solver:
  • 11 Answers
This sounds like a bad main control board. Try unplugging it for 10 minutes then replug an try again. If you get the same results replace the main controller.
Posted on Jun 16, 2010
SOURCE:
Machine starts, fills with water & then nothing... clicks on and off & time counts down. Won't spin or drain water... have cleaned filter & removed pump to check it-- all good--- then worked for two loads...
YOUR ISSUE SEEMS TO INDICATE TO AREAS TO LOOK INTO THE NON WASH OR NO AGITATION USUALLY IS DUE TO A BAD WATER PRESSURE SWITCH, THE NO DRAIN NO SPIN IS USUALLY DUE TO A CLOGGED PUMPED OR IMPEEDED PROPELLER, ARE U SURE U CHECKED IT WELL? THE ONLY OTHER THING COULD BE IS UR CONTROL BOARD IS MIS COMMUNICATING WITH UR DRAIN PUMP?
SEE PICS
May 26, 2015 | Washing Machines
Washing machine wont wash or spin, just fills and drains
THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
Apr 24, 2009 | Washing Machines
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Whirlpool awm 5145-2
The filter area permanantly holds water, this is correct,suggest that you have a faulty inlet valve. Regards Engineer
Jul 26, 2007 | Whirlpool AWM5145/2 Front Load Washer
Washer fills up but won't agitate
get your screw driver and lets start.. first unplug the machine from the outlet, you have to access the water level sitch so remove the tab and there is the bandidt, knock him with the screw driver and if this not funcion replace it..good luck I dont tell you to check the thin hose in the water level sitch becouse you said its fill all right.
Aug 06, 2006 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch Exxcel WFX 3267 Front Load Washer Logo
151 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
