1-800-223-8566 m-f pst 8-4
Call the number above, give them your model #, the serial number
(located on the right side of the safe next to the model number), and
your key code. They will provide you with the combination to your safe. your combination number will be provided to you immediately.
Also, you can try
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial
CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door
open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number
FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO
(2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE
(1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Take care.
you can also try this,
Clear the combination-lock tumblers by rotating the dial clockwise
several times. Set the dial to 0.
Turn the dial clockwise fully four times, and stop on the first number
for the combination lock on the fifth turn of the dial.Turn the dial counterclockwise fully two times, and stop on the second
combination number at the third rotation.Turn the dial clockwise one time past the third combination number, and
stop at the number the second time around.Turn the dial counterclockwise to the fourth combination number. Insert
the key, and turn clockwise to unlock the safe.
Please rate this, if it is helpful.
Take care.
