Philips GoGear SA3245/37  Digital Media Player Logo
Posted on Jun 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does volume label mean? - Philips GoGear SA3245/37 Digital Media Player
k24674
Level 3:
  • Philips Master 8,093 Answers
  • Posted on Jun 16, 2010
k24674
Philips Master
Level 3:
Answers
8093
Questions
0
Helped
4675455
Points
21596
When a hard drive has been formatted, the user can give the storage space created a name: that is the volume label.
For example, on a PC computer the main hard drive is recognized as C, the CD-Player as D: and if a USB key is plugged in it gets drive letter E:
In addition to these Drive letters, the user may choose to give a more "meaningful " name to one or all drives. This additional name is the volume label. It is usually optional on PCs.
You digital media player is also a hard drive and the storage space on the media player (where you store your files, songs) can have a NAME or volume label.
3answers
I am converting Fat to NTFS convert l:/fs:ntfs the drive is 2gb what do i enter for the volume label for that drive
You need to locate the current volume label on the drive.
The easiest way to do this is from the command prompt, you type in vol(space) then the drive letter you are converting & press enter. It will then tell you the volume name, and then on the second line the serial number for the drive.
Why is volume label for the C drive is OS in stead of system when looking up volume label?
If I understand you correctly, you are asking why the volume label for C Drive is called "OS" instead of "System". Is this correct?
1helpful
2answers
Memory card 1GB volume label
My Computer. Right click Format > Volume Label.
My Computer. Right click Properties > Volume Label.
Start > Run / Search. Type cmd ENTER. Type label x: [name] x being the drive letter.
1helpful
Looking for volume control
Take a look at this:
Labelled No.8 = Volume Up button.
Labelled No.9 = Volume Down button.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Cannot format octagon veridisk T118 usb
Try this
Microsoft Windows 95, 98, ME syntax
Formats a disk for use with MS-DOS.
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B | /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B | /S] [/C]
/V[:label] Specifies the volume label. /Q Performs a quick format. /F:size Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88). /B Allocates space on the formatted disk for system files. /S Copies system files to the formatted disk. /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. /C Tests clusters that are currently marked "bad." Microsoft Windows 2000 and Windows XP syntax
Formats a disk for use with Windows 2000.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/A:size] [/C] [/X]
FORMAT volume [/V:label] [/Q] [/F:size]
FORMAT volume [/V:label] [/Q] [/T:tracks /N:sectors]
FORMAT volume [/V:label] [/Q] [/1] [/4]
FORMAT volume [/Q] [/1] [/4] [/8]
volume Specifies the drive letter (followed by a colon), mount point, or volume name. /FS:filesystem Specifies the type of the file system (FAT, FAT32, or NTFS). /V:label Specifies the volume label. /Q Performs a quick format. /C Files created on the new volume will be compressed by default. /X Forces the volume to dismount first if necessary. All opened handles to the volume would no longer be valid. /A:size Overrides the default allocation unit size. Default settings are strongly recommended for general use.
NTFS supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K.
FAT supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes).
FAT32 supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes). Note that the FAT and FAT32 files systems impose the below restrictions on the number of clusters on a volume:
FAT: Number of clusters <= 65526 FAT32: 65526 < Number of clusters < 268435446
Format will immediately stop processing if it decides that the above requirements cannot be met using the specified cluster size.
NTFS compression is not supported for allocation unit sizes above 4096.
/F:size Specifies the size of the floppy disk to format (160,
180, 320, 360, 640, 720, 1.2, 1.23, 1.44, 2.88, or 20.8). /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. Microsoft Windows 2000 and Windows XP recovery console syntax
format [drive:] [/q] [/fs:file-system]
drive: Specifies the drive to format. /q Performs a quick format. /fs:file-system Specifies the file system to use (FAT, FAT32, or NTFS) Examples
When using the format command, remember all information on the drive you wish to format will be completely erased.
format a:
Would erase all the contents off a disk. Commonly used on a diskette that has not been formatted or on a diskette you wish to erase.
format a: /q
Quickly erases all the contents of a floppy diskette. Commonly used to quickly erase all information on the diskette.
format c:
This would erase all the contents of your C: hard disk drive. In other words, unless you wish to erase all your computer's information, this command should not be done unless you're planning to start over.
Or
Right click My Computer-->Manage-->then go to Disk Management
and select the to format right-click it and click format. Thats it Your drive will format and You can also choose in which file system you want to format your drive.
For further help or to thank me mail me on my email [email protected]
2helpful
2answers
I dont know wat to put in volume label cause i cannot formta it!
you do not require to put anything in the volume label infact there must be a check box under the volume lable box uncheck it and try.
if the problem persists simply put any label keeping in mind it dose not match your existing drive label.
thank you.
VOICE TOO LOW
When you talk on you phone make sure your volume label is up. There is a key in right hand site on top. Press up / down for adjusting the volume. if you seen the volume label is fully up but nothing to be change in voice, its mean the internal speaker is damaged. Replace it. And about your voice is not loud from other side then replace that microphone also. I think that's a common problem of Nokia N73 mobiles.
Thanks
1helpful
Can't get sound from TV alone. Am using an optical audio cord. It is hooked up through a digital cable box. Even before this we couldn't get sound from TV alone.
I assume that you mean your TV speakers are not operating OR you do not get audio from TV channel sources.
If you want your TV speakers to work, make sure that the TV speaker is enabled in the TV setup menu.
If your TV is connected to the receiver to get audio from it through external speakers powered by the receiver, then make sure you have a connection from the TV labeled as "variable audio out" into the receiver on a panel labeled as something to the like of "TV/SAT IN" or "TV/SAT AUDIO IN." Then, turn the volume all the way up on the TV, then operate it with the master volume on the receiver.
2answers
Problem with opening ini files...
from each computer:
right click on a .ini file,
select 'open with...'
choose notepad and select the box that says 'always use the selected program to ope this kind of file'
click 'ok'
5helpful
3answers
What's volume label
when i go to format my mp3 it say windows can not complete format plz help.
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
