My toshiba regza 32LV67U LCD TV TV/DVD combo has sound and powers on but after a second or two the screen goes black what could be wrong and how much would it be to fix it money wise and could it be done by me or would a shop be the only way to have it fixed.
Sounds like the laser pickup unit to the DVD player is faulty. Contact any service technician to replace it. The disc mechanism should be taken out of it to replace this part.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. [email protected]
Hi I hade the same problem taking it off when i wanted to hang my T.V., right abouve the stand there are 6 allan keys and 1 srew you have to take them out and the stand will just fall off!!!!! :-)
