This is usually a keypad stuck key error, usually caused by a bad keypad or sometimes caused by your control board.
F7 usually means a stuck key on the keypad. I've also seen it caused by a greasey buildup on the keypad connector into the control board. Try pressing each button on the keypad followed by cancel. See if the buttons are registering with the control - should get a beep or some function (execpt up/down buttons need a cook or time function enabled first). If one of the buttons seems inoperative it may be stuck, in which case you probably need a new keypad.
Best Regards,
Diana
This indicates the ERC Electronic Range Control has failed. First check the key pad. Press each button one at a time. You should feel or hear a click and feel the retraction. If any button is not working the problem is likely in the key pad. If all seems good the control is at fault. Check to see if you have power going into the control. If you do and nothing is working the control board or ERC needs to be replaced. Here is a link for checking and replacing an oven control. If you need diagrams and illustrations of your specific model enter your model their. All parts come with installation instructions.
