This is a 2 1/2 ton unit, if it is a package unit, usually the installer has to install a filter rack in the return air duct. Try opening the side panels and see if they installed a filter rack in the unit itself, if not it could be in the ductwork itself, usually there will be a filter slot cut into the side of the sheetmetal duct, on the side, you remove the cover and replace the filter.
Now if you still have not found the filter, there is one more place they could be, in the structure there are large grills, these are your return air ducts, if you put a tissue on it, it will **** the tissue to the grill, sometimes these grills are hinged and the air filter is installed inside, just behind the grill.
If you still can not find it, then the installers, forgot to install one. Good Luck
Contact me if I can help you furthure.
Paul Gibson
