Re: Thermador 30" range, gas top, electric oven. The...
You may want to send us the control board to see if we can rebuild it and save you some money compared to replacement. Best Regards, bruce www.fixyourboard.com
ThermadorContact us for help with service & repair needs. ... The anti-tip bracket is not needed for 48" Harmony units. However, the anti-tip ... Oven light is not working properly. Replace ... Buy a replacement bulb. View the ... The rack positions that you would use when baking 3 racks in the convection mode would be racks 1,2 and 4.
Huge selection of Thermador Range/Stove/Oven parts in stock. Same day ... Stove top potentiometer Kit that contains 2 potentiometer's and 1 simmer controller.
If oven does not heat check heating element and oven control. Follow also suggestion below: "
It won't bake
Usually,
when an oven won't bake, it's because the bake element is burned out.
The bake element is the black, pencil- thick tube at the bottom of the
oven. When the oven heats, the element glows red. This element has an
expected life-span of several years. It may last for only one; it may
last for many more. When the element burns out, you need to replace it.
It bakes poorly
Here are two instances of when food "bakes poorly:"
When
the food you're baking is done on top but not on the bottom--or when
baking just takes far too long to finish--the bake element may be
burned out.
You may get fooled into thinking it's
working, because the oven is hot inside. But many electric ovens use
the broil element, too, during the preheat and bake cycles. So the food
may be getting heated only by the broil element, which causes poor
baking results.
If the bake element is burned out, replacing
it should solve the problem. Otherwise, you need to further
troubleshoot the oven's electrical system to locate the defective wire
or component.
When the temperature is consistent but too
high or too low, it could be one of several different things. First
check to see if the thermostat sensing bulb has come loose from its
holder. It could be lying on the floor of the oven or resting on the
heating element. This would cause the oven to not heat correctly.
If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
Electronic
ovens with a digital display use a sensor to monitor oven temperature.
To solve temperature problems for these models, you may need to replace
the sensor. On some digital-display models, you can calibrate the
temperature using the key pad. See your operator's manual for details.
Ovens
without a digital display often use a mechanical system for controlling
temperature. On many of these units, you can remove the thermostat knob
and adjust the knob itself to more accurately represent the actual
setting of the thermostat.
If, when you remove the knob,
there's a screw on the back of it with a small calibration plate, you
can loosen the screw, adjust the plate, then tighten the screw again.
If the knob isn't adjustable, and the oven temperature is off by more
than 30 to 40 degrees, you need to replace the thermostat to solve the
problem.
I am quoting above because I really need help. "When I push any of the function buttons on the oven console
(Timer, Bake, Broil, Clock) the display shows 0FF in red next to the
clock. The oven will not turn on and the timer will not work. I can not
find any troubleshooting information on this problem. The oven is a model RDDS30V. Any help would be greatly appreciated!"
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
I found capacitor c3 (68 uf 35 volt) had leaked and dried up, causing the display to fail. I unsoldered and tested c1, c4, c7, and made sure they were good, using a digital multimeter with the ability to test capacitors. C3 also had visible signs of leakage. Works like a charm again, and the display is bright like new!
