Hi. Most speed problems on scooters, can be the throttle pot ( wig wag ), or the motor brushes.
Also check all battery lead connectors, and the motor lead connectors.
While you are driving along, try moving the speed lever slightly up and down, not in and out as you normally do. If the speed changes, it is probably a faulty pot.
Do you have a high/low switch, or an indoor/outdoor switch that changes the speed? These sometimes cause speed changes. You can fit a new switch or by-pass the switch, and have it on high all the time.
Good luck. Neil.
