Hi. A faulty speed control pot ( wig wag ) will cause this problem.
While you are driving along on a smooth surface, move the end of the lever carefully up and down, not in and out as you normally do. Doing this will help to see if there is a problem with the pot, it will cause the speed to vary or change.
Can sometimes be caused by stuck or worn motor brushes.
Good luck. Neil.
