Not to sound dumb...but there is a slide up and down button with a lock on it on the side...you should be able to slide that button away from the lock position and unlock it that way...Hope it helps
mine doeshave a slide button but everytime i try either direction it still says its locked...
It could be that the tab on the motherboard is stuck and will not move back to the "not locked" position... If you have access to hardware screwdrivers, take out the screw that is on top of the usb port and from there you will have to pry the cover off. I used my fingernails and did it carefully. The screen is connected with a data cable and is not to be removed. From there on the side with the headphone jack you can see the white tab sticking off of the motherboard. Looking at it from the headphone jack side the slider is white. If it is moved to the right it is in the "locked" position. You can move it to the left and this should unlock the keys. You might look to see if the slider is soldered on on the four corners while you are there. If it is not connected to the motherboard it might automatically lock the keys so you would know something is wrong. Hope this helps. =)
SOURCE: My RCA Pearl TH1702-A MP3 Player freezes at
Wow thanks. I had the same problem and your solution worked!
Thanks so much
SOURCE: I have a TH1702-A RCA MP3 player and when I turn
Taking out and replacing the battery might help, mostly.
There's also a trouble shoot page:
http://voxrightnow.custhelp.com/app/answers/detail/a_id/7534/session/L3NpZC83MTZlM1ktag%3D%3D/kw/TH1702/p/158/r_id/103795/sno/0
When needing the manual look here:
http://www.voxxsupport.com/images/manuals/TH1702/media/TH1702_DOC_OM_ENGLISH.pdf
I'd appreciate your vote if this helped.
For more assistance, just add a comment in this reply.
SOURCE: usable memory exceeded please remove
Hi lauriankilla...
Sounds like your RCA Pearl is full and it is asking you to delete some of the music/files that you have on it before you can add any more music/files.
If you want an easy way to delete the files then follow the instructions below
Please take time to rate me
Deleting Files,Pictures,Videos,Audio Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
