Sony KDF-E60A20 60 in. LCD HDTV Logo
Posted on Jun 15, 2010
What does 3 flashing red lights mean on a Sony KDF-E60A20?
Andrew Chrostek
Level 1:
Guru:
  • Contributor 187 Answers
  • Posted on Jun 15, 2010
Andrew Chrostek
Contributor
Level 1:
Guru:
Answers
187
Questions
0
Helped
44719
Points
26
I'm having the same problem with my tv (wega sony kdf e60a20) just like a few other people here, with the sensor cutoff fuse, how do you replace this item?
If you mean the thermal fuse, the set should have a red blink code of 5 blinks. The thermal fuse is way inside on the frame of the lamp housing but can be tested with rear cover removed.
If you have one bad the red blinking light will have to display some code.
Tv comes on for 2-5 minutes then goes off
I can help you to solve your Sony KDF-E60A20 tv problem.
Does tv turn back on itself OR standby light start flashing?
If standby light flashing, please count how many times it flashing after three seconds long pause and let me know to diagnose problem.
Thanks.
Sony kdf e60a20 red lamp lights blinking
I do know it is important to know how many times the red light blinks.
2answers
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
2answers
TV won't turn on and red light flashes 6 times.
MINE DID THAT AND IT WAS THE THERMOSTAT FOR THE BULB
Sony kdf-e60a20 60inch
Yes, it's your thermal switch, had this problem and changed the bulb, no help. Got it checked by tv repair and they changed the switch.
2helpful
3answers
KDF-E60A20 Red Light Flashing 6x
My TV KDF-E60A20 is now Fixed. My tv was overheated and Thermal Fuse Located bottom of the lamp burned. I replaced a different Thermal fuse part from 191000644 to 191002393
at www.partstore.com
search for part number. thank you for the review it's help me a lot
thank again
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
