SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle
SOURCE: GE gss25ifrf ww Ice maker
you will need to replace the dispensor board part number WR55X10444
SOURCE: TFX22CR GE refrigerator TFX22CRXFWW does Not dispense ice.
I had this problem with a similar refrigerator. The problem was the slide switch burns itself especially if you slide it from ice to water while holding the glass in to get ice and water into your glass. Better to slide it to ice, press the glass in to get ice, release the glass to stop the ice, slide the switch to water, then press the glass in again to get water. I "fixed" mine by removing the control panel and soldering some of the connections on the slide switch together so that we now have no crushed ice function, but the ice cubes work again. You can also replace the circuit board in the control panel to restore it to like-new operation. I could not find a place to order just the slide switch.
Not sure if this is the same problem with your unit, but sounds the same.
SOURCE: ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
